Qbasic <=> Stamp2 communication ? (Qbasic primarily) — Parallax Forums
CJCJ Posts: 470
edited 2005-12-17 04:56 in General Discussion
Does anyone know how to get bidirectional communication between a BS2 programming port and Qbasic working?
I have been able to get the stamp to send data to the PC, want to be able to control the flow so that data is not lost
basically like this
PC sends the read command "00"
stamp replies with data
just that I have been unable to change direction without resetting the stamp via DTR (don't want to hack a cable)
1. what method of opening the port is suitable for this?
2. what commands are used to read from / write to the port?
I tried opening the port in random access mode, opens ok but get a device timeout on the "print #" line (the method I found
online to talk to a modem)
edit: been using the standard debug settings for the port 9600 8N1
Post Edited (CJ) : 12/17/2005 4:36:39 AM GMT
    edited 2005-12-17 04:36
    Cj,
    It's been a long time since I used Qbasic to communicate with a Stamp, but I will take you back a few years
    when I was writing Qbasic to Stamp code left and right.
    As far as the DTR line, there is a software solution (provided in link below) as well as a hardware solution. The
    hardware solution uses two caps in a specific configuration. ( ASCII below )
             .1uF
    ATN >--o--||----< DTR ( DB9 Pin 4 )
           o--||----< VSS ( DB9 Pin 5 )
             .1uF
    webpages.charter.net/schwabelove/BasicStamp/Communication/Index.html
    Beau Schwabe
    IC Layout Engineer
  • CJCJ Posts: 470
    that just about covers all the bases, thanks
