14 or 16 bit ADC and a BS2, anyone?
Hello folks,
I have· a need to measure some analog input at a resolution higher than the 12 bit ADC chips I've been using with BS2.· Anyone used a 16bit A/D chip and your BS2 before?· Which one worked best for you?· This is for a proof of concept QA station for a customer, so long term we'd source a NI Daq card if we got the job, but for·just·rough development·I'd like to use a BS2 and a 16 (or could even use 14) bit ADC.
Regards!
Regards!
A lot depends on the input range you require, the number of channels, and not least, your soldering capabilities. A lot of these come in SSOP or DFN packages.
Tracy Allen
www.emesystems.com
I have used the LTC1298 for a few projects with good success. I'll look into their 24 bit IC. I only need 2 channels, and need a DIP package (I don't even try SMT stuff anymore, always send it to PCB fab shop to make a carrier if I can't get the part in through hole).
Many thanks!
