Anyone thinking about entering the "InkJet Contest" ?
Bean
I haven't heard anyone mention it yet.
Have you guys seen the announcement ?
http://forums.parallax.com/showthread.php?p=561510
I've got a couple of ideas, but I'm just too damn busy to experiment with them right now.
Bean.
"SX-Video·Module" Now available from Parallax for only $28.95
http://www.parallax.com/detail.asp?product_id=30012
"SX-Video OSD module" Now available from Parallax for only·$49.95
http://www.parallax.com/detail.asp?product_id=30015
Product web site: www.sxvm.com
Those that would give up freedom for security will have neither.
Bean.
<goes all secretive, and starts pondering>
Steve
·If I am unable to come up with an idea, I sure look forward to seeing the contest results as there is a lot of talent on this forum.
When HP first approached us about this whole idea I thought to myself "printing and microcontrollers, so what?". It wasn't until I spent a meeting or two with that the whole picture really came together. First, understand that they came to Parallax because we have a very innovative customer base. You needn't be an electronic engineer to use our products. Our customers often have specialties in a variety of fields. And HP has a technology they're opening up to the masses at some level. A combination of patent expiration, a thermal inkjet product line with more uses than in·traditional printers, and a fairly simple hardware requirement make it ideal for sharing with you. And for the big size of HP, I'm amazed at how well they've been able to support a small company like Parallax to implement their vision.
As for the contest, maybe you need some ideas about some things that can be done with the TIJ 1.0 inkjet pens. In no particular order, how about this:
The first thing I did was to fire all twelve nozzles as quickly as the BS-2 could muster - essentially creating an airbrush, but without the *air*.· The cartridge itself vaporizes ink droplets with heat (seven times the surface temperature·of the Sun!) and the resulting ink explosion shoots each droplet up to 5 or 6 inches.
Since each nozzle is independently controlled and the firing rate is infinitely variable (under your program's control) very precise (single droplet in picoliter sizes) is easily achieved.
Autonomous, robotic art projects with full text capability too?
How about Paint-bot?· Seek out an opponent, and "blind" his photocell...
Use a single nozzle and write script?
How about interstitching two or more cartridges together and creating a wider print swath?
Create a self-alignment process that will interstitch two print heads in unison, resulting in higher output resolution applications (think barcode!)
Real time, hard-copy, strip chart recorder with no moving parts?
Write text across a wall as the Boe-bot drives by?
Real time remote industrial product serial numbering printing system?
Although this is an INKjet cartridge, sometimes I like to think of it more as a LIQUID dispenser of sorts - a very precise one.· I'm not saying you could (or should for that matter) put anything but ink in that device - but what if...?· Gee, how about an autonomous robotic cockroach assassin?· A single droplet of insecticide applied to the victim - no overspray, no environmental concerns.
As Ken said, HP was really interested in seeing what this community might come up with (don't get a big head here, but the collective talent in you'all makes even big companies like HP stand up and take notice).·
Read the Foreword by Frank Cloutier·(downloadable on the Contest page)...it's quite inspiring.· Frank was the guy that invented this technology which has since become HP's largest division.
As Frank says, "Go not where the path may lead...Go instead where there is no path, and leave a trail..."
Are you sure I can't enter the Contest Ken?
Matt
Matt Gilliland
Put an IR range sensor in there so that it doesn't try to print when it's far from the box...or some other proximity sensor...
Put in an accelerometer so you could do one long sideways swipe to print the label longways, or if you were to move the unit and swipe it up and down, it would slowly print out each part of a longways message.
Maybe have it work in tandem with a IPC code reader in that it would ID the box and the printer would label teh box with real world text!
Recreate the Mona Lisa on a canvas! Use encoders for position.....heck, you guys working on the CNC machine could take the print head and fill it with photoresist and print on your circuits!!
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Intially I just loved the idea for the novelty, but the utility is rapidly sinking in.
I used to operate a silk screen printing factory.
We could and did print 10,000 photo-separated color T-shirts in 3 days with some fairly simple technology. Silk screen is every where {the glass Coke bottles, 55 gallon drums, logos on car doors, wall paper and much more}.
I imagine that having such a highly accurate printing head to bring to the surface can do away with a lot of sticky lables for price tags and other such items. And surfaces don't have to be flat, they can easily be convex or if the print head can get close enough, a bit concave.
Inks are a big question. Many applications would want indellible ink which I seem to believe is not currently available in Ink Jet. The inks seem to be limited to certain porous surfaces.
I don't see any problem with printing Chinese if you can download text via wire or rf link as you print.
http://www.hp.com/hpinfo/globalcitizenship/environment/productdata/pdf/ij_51604arevb_us_eng_v2.pdf
"OEM NMEA GPS Module" Now available on ebay for only $19.99, FREE shipping until 2006!
Product web site: http://www.allsurplus.net/Axiom/
Post Edited (Mike Cook) : 12/9/2005 5:49:39 PM GMT
Could you expand on the following:
Are there any specific examples you could give?· What range does the boiling piont (and condensation point) need to be in?· Is this covered in the "spec sheets" (I have not looked yet, I an a lazy American)?
What type of compounds shoud be avoided (pH, Solvents, etc.)?
John R.
8 + 8 = 10
Water works. The extent of the "data sheet" approved and published is what you'll find in Matt Gilliland's book. As far as compounds to avoid, just use common sense and basic chemistry. We won't comment much on chemicals and food-related uses, as they're not in HP's interest. And any lawyer would advise us not to be as bold as we've been in providing you with a list of ideas, so our creative side will be a bit quiet.
- Ken
What are a handful of lawyers trapped in a sinking boat?· A small start.
Thanks, I understand...
John R.
8 + 8 = 10
That would be slick! However, I don't think it can happen, at least not with conventional methods. The etch resistant material that is used on systems such as the Pulsar method rely on the plastic that is in the toner of a laser printer, Inkjet's don't have this plastic in them. [noparse]:([/noparse]
Toner is ~%50 plastic, from what I understand.
And I don't know of any photoresist that would be decent, yet still go through the nozzles of the inkjet. There are conventional inkjhet printers that can print on a solid surface, the CD printers that print directly on the CD.
Knight.
This message transmitted with 100% recycled electrons.
Gravity doesn't exist. The Earth sucks.
Make a man a fire, and he will be warm for the night.
Light the man on fire, and he will be warm for the rest of his life.
Traditional etching is on copper plate with ferric chloride. Historically, there are a wide range of materials that have been used. Wax, tar, oils that dry and harden, pastes that never harder, rosin melted onto the plate.
I suppose a water-based polymer [noparse][[/noparse]latex or acrylic or even just 'white glue'] might may a good acid resistant barrier for the short amount of time needed.
Since everyone is already using scour and abrasives to clean other resist materials off, there doesn't have to be a nasty solvent or remover.
On a more interesting side, water could actually be used in its pure state.
Then the material would have to have some feature that is useful hydroscopic feature. Water might be used to cut away from a gelitin-like material and to expose the underlying material [noparse][[/noparse]maybe copper]. If there were a way to fix the gelitin afterwards into an acid resist, this could be useful.
There are also dyes which might simply block a certain wavelength of light. Then the photosensitive material could be exposed and developed. This may not be useful for 'circuit boards', but for making some very very tiny things [noparse][[/noparse]like stress guages], it becomes an interesting prining process. 96 dot per inch is fairly small.
Excuse me, I am rambling. I have thought of one entry, but I am not going to tell anyone as I am still trying to decide if it would be worth it.
I can't seem to locate the deadline yet.
Here is a thought using the regular ink...
Simply print directly to a photo sensitive board. ( Printing must be done in the dark of course )
This way you eliminate the step requiring a transparency with the photo resist.
Beau Schwabe
IC Layout Engineer
Something no so related to making electronics.
We live in a culture that depends on printing in so many ways.
I imagine that you could combine a barcode reader with the print head and it could read the barcode for a library book and print the due date inside the book. I believe they use a sheet pasted into the book so that it won't fall out. Saves a bit of time, eliminates date stamps that can be wrong or unclear.
Or you could read a barcode for a customer's vehicle ID number and stamp the date of an oil change and tune up on a sticker placed on the car door or under the hood. All sorts of maintance logs.
Being liquid ink, I guess you always have to position the printhead above the object. So the car door is out. Still there are a lot of production line applications. Inventory control. Expiry dates. Manufacture origin control. Lot numbers. Size and description on your Levis.
What about prescription medicine bottles in a large pharmacy. McDonalds could put your name on the BigMac box if you had a bar coded 'preferred customer' card.
And then there is a lot of specialty advertizing items.
That would be a good application for a thermal printer.
No ink to replace, no smudging the ink.
You can use label maker rolls that are cheap.
I have seen thermal printers for under $10 on the net, it's just to interface them to a stamp...
I wonder if they make a spray on coating that allows one to use own paper?
Bob N9LVU
-Matt
Matt Gilliland
Ink is not "boiled-off" per se.· It is so quickly heated, that it goes right through its boiling point and reaches the so-called "super-heat limit", where the droplet then goes through a vapor explosion (see Frank's Foreword, downloadable·on the·Contest page).· However, because the mass is so small, the temperature cools rapidly.· Even though the heat is (7) times the Sun's surface, it's for such a short time that the total amount of energy delivered to the droplet is only about 40 micro-joules.
I've never felt any heat from the vaporized ink, and I'm not sure how you would go about measuring an individual droplet - I guess it could be calculated though?· My slightly educated guess would be that by the time the droplet reaches the target, it's at room temperature.·
Anyway, I've put my fingers on the nozzle plate, while firing 12,000 drops per second, and the only thing I've ever detected is a mess on my fingers...
Matt
Matt Gilliland
For those who have been interested in firing a substance other than ink, I have a bit more information for you. The two key aspects to firing a thermal inkjet cartridge nozzle of this style are viscosity and boiling point. Shooting a drop of ink requires the formation and explosion of a vapor bubble. If the non-ink material you're considering meets these characteristics it might fire quite well:
Molasses and syrup won't fire, nor will moist oils.
·1+1=10
In fact, you could be the FIRST person to enter the contest. Oh, what a shame it will be to see all of those great prizes go to people who won just by entering. Oh well. We'll be lucky to award the 12 prizes. Why is it so difficult to give stuff away. . .
Ken
·1+1=10
Post Edited (Paul Baker) : 12/14/2005 11:37:55 PM GMT
·1+1=10
Post Edited (Paul Baker) : 12/14/2005 11:47:03 PM GMT
Ken
Anyway...
Here's an idea...
Build an XYZ rig, or possibly add another couple of axis of movement, and mount the inkjet head on it. Use cartridges filled with pure water and place the entire assembly in a VERY COLD room...
Ice-scuptures anyone?
Don't visit my new website...
Cool idea. (hee hee hee "cool" get it).
Bean.
Forget about the past, plan for the future, and live for today.
For those of us that would like to build the interface board for the HP Q7543A Cartridge Holder for HP51604 Inkjet Cartridge, can you give us a link, preferably a Digikey part number, for the 452-00020 Connector, FPC/FFC, 16 position, 1MM, right angle. Or do you plan on selling this part?
Also is it possible to purchase empty HP51604A Inkjet Cartridges?
Post Edited (Mike Cook) : 12/16/2005 12:57:22 AM GMT
As far as I know, empties are not available at this time.· (Empty-ing would be up to you).
A suitable connector (there are several to choose from) would be Hirose #FH21-16S-1DS (Digikey #HFG16T-ND)
-Matt
Matt Gilliland
