New 4x20 Serial LCD!
I just noticed the new 4x20 Serial LCD on the Parallax·home page!· Thanks to the Parallax team once again as this looks like a good product at a great price.· I have been looking forward to an affordable four by twenty, backlit·serial display.
Tim
Edit:
Sorry all, I meant to post the link and missed it.
http://www.parallax.com/detail.asp?product_id=27979
Post Edited (Tim-M) : 12/1/2005 6:04:50 PM GMT
Tim
Edit:
Tim
Jon Williams
Tim
·· New beans, cool beans...The LCDs are now available.· Everything's taken care of, and you can now start placing those orders!·
Chris Savage
Parallax Tech Support
csavage@parallax.com
73
spence
k4kep
The new beans are cool beans indeed, and such a deal to boot!· The timing is perfect too - I was just putting an order together to place tomorrow morning so I'll include 4x20 LCD's as well.
Thanks for letting us know,
Tim
· I know we've talked about this in the past, but since this is a new product I wanted to ask if you will be offering a bezel to go with the 4x20 LCD...· Any chances?· Something like the 2x16·Seetron product perhaps??
Feeling Hopeful,
Tim
Chris Savage
Tim
Jon Williams
http://www.seetron.com/cgi-local/SoftCart.100.exe/online-store/scstore/c-serial_displays.html?L+scstore+legm9235+1139975890
Tim
You can always use an oversized clear plexiglass sheet and some spray paint
I suggest you make the sheet equal to one side of your project box [noparse][[/noparse]the open one of course}
1. Drill your holes for the mounting while it is still covered with that sticky paper. This includes switches, etc.
2. ON the INSIDE surface - carefully cut a rectangle the size of the window you want and make sure it is positioned rightly.
3.Remove all the sticky paper EXCEPT that 'window' square.
4. Spray paint in your choice of black, white or what ever.
There you have it.
Tim
Just a kindly reminder that once the 'Add To Cart' button and the price are added back onto the 4x20 LCD description page, I'll be more than happy to complete my online order.
Thank You,
Tim
·· You're all set!· $39.95 and ready to order online.· Take care!
Chris Savage
Tim
One alternative to a purchased bezel is to have some cut for you at a sign shop that uses "lamacoid" material. Its the stuff that gives white lettering on a coloured background, for example to make office signs. The machine that cuts the lettering can be set to cut right through, giving a very nice bevelled edge.
At a very progressive shop, you can give them an Autocad drawing because the engraver controller can read the cad drawing directly, although some shops don't realize it. However, the basic sign setup software can do basic rectangles easily.
To see an example, go to the Projects forum and go back to 8/28/05 and have a look at "Wireless Controller". Way down at the bottom is a pic of a small controller I built with a bezel as described. Its mounted with 2-sided tape or silicone seal.
Cheers
I took a look at your Wireless Controller project and those ideas are great, thank you for sharing them. That method provides a clean and professional final product too, and that is what I'm after. It just seems much to difficult to 'finish' an LCD display easily and that surprises me to some extent. I understand that LCD's vary from manufacturer to manufacturer, but you would think that there would be more than one (or nearly one) 'off the shelf' option to choose from.
Tim
Jon Williams
Thank you,
Tim
Jon Williams
Tim
Timothy Gilmore
