I am a bit confused on this DAC chip — Parallax Forums
metron9metron9 Posts: 1,100
edited 2005-12-05 05:44 in General Discussion
Since I was cleaning up my play area and found this tube of DAC0800's I thought I would give it another go to see if i could hook it up and make it work.
AS you can see it looks like a mess. I have 9 volts instead of 10 volts on pins 14, 4 and 2 and I have another battery connected to the +9 I am using for using for those inputs to get +18 volts for pin 13.
I am confused with a few things.
1. It says it is a current output chip
2. the diagram shows a Vout to 20 Vp-p
3. The arrows on pins 4 and 2 point into the chip
So with that said, its hooked up,
I hooked up pins 5,6,7, and 8 to +4 volts to make them HIGH
I hooked up pins 9,10,11,and 12 to Ground to make them low
I then measured the voltage on pins 4 and 2 making each pin from 12,11,10, and 9 HIGH
Results are
Pin 256 1 2 4 8 Digital Byte Value
12
0 | 1 | 0 | 0 | 0
11
0 | 0 | 1 | 0 | 0
10
0 | 0 | 0 | 1 | 0
09
0 | 0 | 0 | 0 | 1
1. 3 1.63 1.59 1.56 1.56 Volts measured for Byte values 256, 1, 2, 4, and 8
Could someone tell me what I should be measuring and how i should measure voltage or current. I just dont get what this thing does.
http://www.national.com/ds/DA/DAC0802.pdf
Hmmm After reading a tad more I see the figure I posted below , the 10k resistors are a simulated load for a typical application I shall endever to measure the voltage across them in the same manner as I did above to see what happens.
Nope, just 6.9 volts measured across both of the 10k resistors, no change when setting any pins high or low.
Think outside the BOX!
Post Edited (metron9) : 12/3/2005 5:59:08 AM GMT
    edited 2005-12-03 15:34
    You need to run the DAC08xx into a current-to-voltage amplifier.· If have attached the circuit from the DAC0808 datasheet.· I have made these before.
    Also, you'll need to change your VCC and VEE.
    You can use a 741 for the op-amp.
    The DAC address bits should·each be pulled high (= 4.7K·to 10K), with your DIP switch (?) taking the input low.
    I've included the DAC0808 datasheet (I think they're all the same, operationally --·basically differences in accuracy.)
    When you get 1st Place in the "Darwin Awards", you're a Winner & a Loser.
    587 x 387 - 23K
  • metron9metron9 Posts: 1,100
    Thank's PJ, that schematic I did not have in the datasheet I downloaded, I think I can make it work now, I am using LM324N op amps, I will have to figure out how to get a -15V supply hooked up I guess that's why I was having no luck.
