SX48 and ExpressPCB
william chan
Hey,
I was starting new project based on the SX48.
Then I found out that ExpressPCB does not have a SMT pad for the 48 pin TQFP.
Anybody has drawn the SMT pads for this chip on ExpressPCB?
Thanks.
Thanks.
Check out this custom component, I haven't used it yet so check the dimensions before you commit to it.
later, Kevin
There are 10 kinds of people in the world.... those that know binary, and those that don't.
Thanks a million.
Seems like the component you drawn is for top surface ( based on the pin numbering arrangement ) but the pad colors seems to be
green which is for bottom surface.
Never mind, I'll change them to red for top surface.
Thanks again.
After you open the file, click on the SX48 component and then select Component\Save Custom Component from the menu.· Mine follows the naming convention used by ExpressPCB:
SMT TQFP - 0.5 mm pitch - 48 pin (top surface)
Jon Williams
engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
Sid
the PN is cstcv_x_q. and the landing is on page four of the pdf doc
http://www.parallax.com/dl/docs/prod/datast/murataresn.pdf
