SX48 and ExpressPCB — Parallax Forums
SX48 and ExpressPCB
william chanwilliam chan Posts: 1,326
edited 2005-12-28 14:11 in General Discussion
Hey,
I was starting new project based on the SX48.
Then I found out that ExpressPCB does not have a SMT pad for the 48 pin TQFP.
Anybody has drawn the SMT pads for this chip on ExpressPCB?
Thanks.
  • mojorizingmojorizing Posts: 249
    edited 2005-11-30 15:35
    Hi William,
    Check out this custom component, I haven't used it yet so check the dimensions before you commit to it.
    later, Kevin
    There are 10 kinds of people in the world.... those that know binary, and those that don't.
  • william chanwilliam chan Posts: 1,326
    edited 2005-11-30 22:29
    Kevin,
    Thanks a million.
    Seems like the component you drawn is for top surface ( based on the pin numbering arrangement ) but the pad colors seems to be
    green which is for bottom surface.
    Never mind, I'll change them to red for top surface.
    edited 2005-12-02 22:05
    I, too, have interest in this with an upcoming project.· I just happened to get a note from ExpressPCB today about a software update and have asked them to add a 48-pin TQFP package to their library.· Mine was built based on the dimensions we use for our own boards.·
    After you open the file, click on the SX48 component and then select Component\Save Custom Component from the menu.· Mine follows the naming convention used by ExpressPCB:
    SMT TQFP - 0.5 mm pitch - 48 pin (top surface)
    Jon Williams
  • nick bernardnick bernard Posts: 329
    edited 2005-12-27 22:19
    can you recommend a footprint for the 50MHz smt crystals i purchased from parallax?
    engineer, fireman, bowler, father, WoW addict [noparse];)[/noparse]
  • NewzedNewzed Posts: 2,503
    edited 2005-12-27 22:34
    I'll make you a footprint if you can send me the mechanical drawing.
    Sid
    i found the mech dwgs @ parallax. then measured my xtal to match the part number with one of the several in the tech doc.
    the PN is cstcv_x_q. and the landing is on page four of the pdf doc
    http://www.parallax.com/dl/docs/prod/datast/murataresn.pdf
