Live or Fry — Parallax Forums
Live or Fry
Tricky NekroTricky Nekro Posts: 218
edited 2005-11-28 22:51 in General Discussion
Look at the schematic below...
I used an 390Ω resistor instead but it didn't work...
Only with this resistor...
Will I fry my stamp
P.S. I use the PIC16C57C and not the stamp module...
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
Post Edited (Provas) : 11/28/2005 9:38:48 PM GMT
  • BeanBean Posts: 8,129
    edited 2005-11-28 21:43
    If a 390 ohm works that's fine and it won't hurt the stamp (or PIC). Actually the 68 ohm is kinda on the low side. Usually 220 Ohms is used.
    But I think your schematic is not drawn correctly.
    Bean.
    "SX-Video·Module" Now available from Parallax for only $28.95
    http://www.parallax.com/detail.asp?product_id=30012
    "SX-Video OSD module" Now available from Parallax for only·$49.95
    http://www.parallax.com/detail.asp?product_id=30015
    Product web site: www.sxvm.com
    Those that would give up freedom for security will have neither.
  • Tricky NekroTricky Nekro Posts: 218
    edited 2005-11-28 21:54
    It's upside down...
    hehehe
    Well, connecting 3X68Ω resistors was the best I could get...
    Is it ok?
    -Rule your Destiny-
    edited 2005-11-28 22:32
    This post is being moved from the BASIC Stamp Forum to the Sandbox.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • JC ElginJC Elgin Posts: 1
    I was going to say, I've used 220 ohm w/o any issue.
    -J.C.
