VIKAY dot matrix module <=> BS2e
Hi,
I just found a used 2x40 alphanumeric dot matrix module from VIKAY (now Arianecorp. Seems very, very cool
....and i'm enthousiastic and looking forward to use it [noparse]:)[/noparse]
It's reference is : V0022401 or to be more precise : 2014STLDYGBND
Unfortunately I cant tell what are the controlers (at least 3 because of its size).
I think i've found the datasheet, which is quit not clear to me :
They say it might be a samsung controler, but no certitude...
I have the pin description, but I dont know commands, etc..
Please help...
Do you think a BS2e can control this LCD and if yes, how ?
Thank you.
PS.
I've just counted the i/o pins (14) and search in google 'for 14 pin lcd' and found this : http://www.myke.com/lcd.htm
Seems the controler is an Hitatchi 44780....because of the similitudes in the pin# & functions. But, do you think there is only one controler ?
Post Edited (Tibot) : 11/28/2005 6:51:26 PM GMT
Please help...
Thank you.
PS.
Jon Williams
Truly Understand the Fundamentals and the Path will be so much easier...
