JIDE detects only 2 com ports
Has anyone else experienced this?
Desktop PC running Win2K,
BoeBot connected to Keyspan USB Serial Adapter (USA19H),
Keyspan detects connection to com4,
Latest JIDE
Fire-up JIDE and select Identify and it scans com1 and com2 only.
Then I try Test Connection. Output is: [noparse][[/noparse]Debug] TSXComm: AutoChoosePort - unsuccessful.
I can't get the JIDE to scan beyond com2.
Latest JIDE
Inside ide program: Projects -> Global Options
Tab Debugger.
regards peter
I tried that and it found the Javelin Stamp on port 4. However, I get an error that says [noparse][[/noparse]Error IDE-0052] Incompatible firmware revision ($f).
I downloaded the latest JIDE (2.0.3) and still get [noparse][[/noparse]Error IDE-0052] Incompatible firmware revision ($f).
The only way to trick it out is to power-off the BoeBot, click Program and then wait until the JIDE displays Resetting Javelin.
Wonder what that means?
That should minimalize any delay.
regards peter
