monitoring current
hello
been looking for a way to monitor current of a circuit
i would prefer an ic circuit where the input could be gated
ive only found the inductive type of set up is their another way
thanks for any help
japer
thanks for any help
japer
AC or DC? What current level? What accuracy is required?
I do this every day, but I don't know how to help without more information...
-dave
This is not a sig. This is a duck. Quack.
·1+1=10
a/c and d/c
as far as current value, just the feedback that the load is on or off
accuracy 2 bit resolution would be good enough.
japer
paul
this sound like a good idea it would show change in value on a loaded circuit
which would be good enough.
thanks
japer
(www.maxim-ic.com)
james
looking at the data sheet. the 8 dip form factor is more what am looking for.
The low operating amps and flexible voltage range is a plus also.
japer.
