Chapt. 7 (Measuring Light)Activity3-bonus
·Is there a way to change the time variable(the x-axis) on the Stamp Plot Lite which would more accurately·display the actual time value?· In the Tracking Light Events activity, the eepromAddress range is 0 to 58(step 2), but on the Stamp Plot Lite, the time value is 0 to 1.17.·
' {$STAMP BS2} ' {$PBASIC 2.5} counter VAR Word DEBUG "!AMAX 1250", CR, "!TMAX 29", CR, "!TMIN 0", CR, "!SHFT ON", CR, "!RSET",CR FOR counter = 0 TO 28 DEBUG DEC (counter * 40), CR PAUSE 1000 NEXTAlso, check out StampPlot Pro at www.selmaware.com.· It's a much more powerful software package with a myriad of display options.· I'm pretty confident you'll be able to use it to display your data exactly as you want.
You can also set up the Debug Terminal so that it displays a time and light sensor column.· Then shade the data and press CTRL + C.· Then, in a text editor, click Edit and select Paste.· Then, you can import the file with a spreadsheet program such as Microsoft Excel.·
There's also some software that pipes your measurements into an Excel graph.· It's called StampDAQ, and it's available from www.parallax.com -> Downloads -> BASIC Stamp Software.
