Using PUT & GET
Dear Parallax People,
On p.245 of the Stamp Manual in refering to Scratch Pad RAM it says that "...each location is always configured as a byte only."··Can I·do the following? :
····················Value·· VAR·· Byte
··················· PUT 0, Value.LOWBYTE
··················· PUT 1, Value.HIGHBYTE
The Stamp Editor didn't balk when I entered the above lines, but I wanted to be sure.
Vern Roach
Vern Roach
· PUT 0, Word value
What the compiler does is generate this code for you:
· PUT 0, value.LOWBYTE
· PUT 1, value.HIGHBYTE
You can also PUT/GET multiple values like this:
· PUT 0, status, Word value
For this the compiler would generate:
· PUT 0, status
· PUT 1, value.LOWBYTE
· PUT 2, value.HIGHBYTE
Jon Williams
Post Edited (Jon Williams (Parallax)) : 11/15/2005 2:13:33 AM GMT
Thanks for being perceptive - Yes, I did mean "Value VAR Word". And thank you for elaborating on the capabilities of PBASIC 2.5. The ability to use GET & PUT very much like READ & WRITE really takes the restrictions off what might seem like a not-too-large RAM capacity. (To 3rd parties: I'm truly a beginner at this!)
Thanks again
Vern Roach
Put 0, value.lowbyte
Put 1, value.highbyte
actually uses less code space than...
Put 0, word value
This is not a problem exactly, just something to be aware of.
-- PJA --
Jon Williams
Jon Williams
·· The ScratchPad RAM is just that, RAM, and has an unlimited number of write cycles, just as variable space does.
Chris Savage
Parallax Tech Support
csavage@parallax.com
I've learned my lesson now. Sorry about any confusion.
·· While we're getting technical, the EEPROM write life of the BS1 & BS2 is 10,000,000 (Ten Million) writes.· The BS 2e, BS 2sx, BS 2p, and BS 2pe EEPROM is guaranteed for 100,000 write cycles before it wears out.·
Oooh, a donut!
Chris Savage
If I put 4 in, I get 4 out. Seems like double digit numbers dont want·to work right.
Temp1 = 42
PUT 1, Temp1
GET 1, Temp1
DEBUG "Temp1=", DEC Temp1
I've tried...
PUT 1,Temp1.LOWBYTE
PUT 1,Temp1.HIGHBYTE
Nothing seems to work.
Edit: Oh yeah I'm using a BS2P40
Post Edited (HIBITDAC) : 11/18/2005 10:31:23 AM GMT
You failed to mention how Temp1 is defined, WORD, BYTE, NIB? It's always best to include the whole program when asking for assistance on a question like this.
Bruce Bates
I've defined as Word...samething, Byte...samething, Nib...samething.
If I...
Temp1 = 38
Put 1 Temp1
Get 1,Temp1
Temp1 = Temp1 / 10
It displays 30, samething with 52 execpt it displays 50. seems like it is adding a zero for no reason.
Post Edited (HIBITDAC) : 11/18/2005 10:41:32 AM GMT
