Using PUT & GET — Parallax Forums
Using PUT & GET
Vern RoachVern Roach Posts: 9
edited 2005-11-18 11:22 in BASIC Stamp
Dear Parallax People,
On p.245 of the Stamp Manual in refering to Scratch Pad RAM it says that "...each location is always configured as a byte only."··Can I·do the following? :
····················Value·· VAR·· Byte
··················· PUT 0, Value.LOWBYTE
··················· PUT 1, Value.HIGHBYTE
The Stamp Editor didn't balk when I entered the above lines, but I wanted to be sure.
Vern Roach
    edited 2005-11-15 02:10
    The code you've posted doesn't actually work -- is there a typo and is "value" actually a Word?· PUT and GET are used to put and get bytes to/from the Scratchpad RAM.· With PBASIC 2.5 you can do this:
    · PUT 0, Word value
    What the compiler does is generate this code for you:
    · PUT 0, value.LOWBYTE
    · PUT 1, value.HIGHBYTE
    You can also PUT/GET multiple values like this:
    · PUT 0, status, Word value
    For this the compiler would generate:
    · PUT 0, status
    · PUT 1, value.LOWBYTE
    · PUT 2, value.HIGHBYTE
    Jon Williams
    Post Edited (Jon Williams (Parallax)) : 11/15/2005 2:13:33 AM GMT
  • Vern RoachVern Roach Posts: 9
    edited 2005-11-15 02:53
    Jon,
    Thanks for being perceptive - Yes, I did mean "Value VAR Word". And thank you for elaborating on the capabilities of PBASIC 2.5. The ability to use GET & PUT very much like READ & WRITE really takes the restrictions off what might seem like a not-too-large RAM capacity. (To 3rd parties: I'm truly a beginner at this!)
    Thanks again
    Vern Roach
  • superoosuperoo Posts: 5
    edited 2005-11-15 06:38
    Just in case you eventually end up short of code space...
    Put 0, value.lowbyte
    Put 1, value.highbyte
    actually uses less code space than...
    Put 0, word value
    edited 2005-11-15 14:32
    Note the EEPROM only supports about a million writes. During normal 'programming' use, this should last a decade or more. If you write to the same location once every millisecond though, you can wear it out in a week.
    This is not a problem exactly, just something to be aware of.
    edited 2005-11-15 14:56
    That's something I hadn't thought about -- ScratchpadRAM is actually EEPROM space, then?
    -- PJA --
    edited 2005-11-15 15:24
    No, the Scratchpad is RAM. That said, PUT and GET (RAM) are analogous to WRITE and READ (EEPROM).
    Jon Williams
    edited 2005-11-15 15:25
    PUT and GET have no effect on EEPROM.
    allanlane5 said...
    Jon Williams
    No,
    ·· The ScratchPad RAM is just that, RAM, and has an unlimited number of write cycles, just as variable space does.
    csavage@parallax.com
    edited 2005-11-15 16:25
    Thanks, guys -- I can breathe again.
    edited 2005-11-15 18:20
    D'oh! Sorry about that folks. "Get" and "Put" are for ScratchPad RAM, which has NO write or read limitations, on the BS2p variants. "Write" and "Read" are for EEPROM, which is on all BS2 variants, and can only be written 1 million times.
    I've learned my lesson now. Sorry about any confusion.
    edited 2005-11-15 18:47
    allanlane5 said...
    Okay Homer,
    ·· While we're getting technical, the EEPROM write life of the BS1 & BS2 is 10,000,000 (Ten Million) writes.· The BS 2e, BS 2sx, BS 2p, and BS 2pe EEPROM is guaranteed for 100,000 write cycles before it wears out.· =)
    Oooh, a donut!
  • HIBITDACHIBITDAC Posts: 40
    edited 2005-11-18 09:40
    I'm trying to write 42 to the scratch pad and when I get it back out it's 420 not 42. It does this for every number execpt for 0.
    If I put 4 in, I get 4 out. Seems like double digit numbers dont want·to work right.
    Temp1 = 42
    PUT 1, Temp1
    GET 1, Temp1
    DEBUG "Temp1=", DEC Temp1
    I've tried...
    PUT 1,Temp1.LOWBYTE
    PUT 1,Temp1.HIGHBYTE
    Nothing seems to work.
    Edit: Oh yeah I'm using a BS2P40
    Post Edited (HIBITDAC) : 11/18/2005 10:31:23 AM GMT
  • Bruce BatesBruce Bates Posts: 3,045
    edited 2005-11-18 10:02
    HIBITDAC -
    You failed to mention how Temp1 is defined, WORD, BYTE, NIB? It's always best to include the whole program when asking for assistance on a question like this.
    Bruce Bates
    edited 2005-11-18 10:38
    I would post my program but its spans 5 slots, and jumps all over the place so you would probably get lost.
    I've defined as Word...samething, Byte...samething, Nib...samething.
    If I...
    Temp1 = 38
    Put 1 Temp1
    Get 1,Temp1
    Temp1 = Temp1 / 10
    It displays 30, samething with 52 execpt it displays 50. seems like it is adding a zero for no reason.
    Post Edited (HIBITDAC) : 11/18/2005 10:41:32 AM GMT
    NEVERMIND..SUPER STUPID moment.
