LC Circuit --> BASIC Stamp? How? — Parallax Forums
prprogprprog Posts: 18
edited 2005-11-14 15:57 in BASIC Stamp
Hello:
I would like to interface a LC circuit to the Basic Stamp. How do I do it ?
Do I need another circuit between this one and the Stamp?
Do you have a any similar circuit or example i can used ?
(this is the LC circuit I would like to used)
    edited 2005-11-10 18:03
    What is it exactly that you want the BS2 to know about the LC circuit?
    Beau Schwabe
    IC Layout Engineer
  • prprogprprog Posts: 18
    edited 2005-11-10 18:27
    I want to measure inductance changes. Like if the coil (L1) is near a metal. Can the Stamp detect this changes ?
    edited 2005-11-10 19:00
    There are several ways to do this, but not with the circuit you have. Are you actually building a metal
    detector, or are you building a sort of BS2 based grid-dip meter? Do you know what inductive values
    or ranges you have?
    There are other ways to do this, but here is an example of a Metal Detector.
    Stamp Based Metal Detector
    This is a "copy" of an old web page that I used to manage....
    Beau's Old Web-Page
    ...See "Coil/Inductor Reader"
    ...and "multiple Inductor Reader (LVDT example)"
    Beau Schwabe
    IC Layout Engineer
    edited 2005-11-10 19:25
    Beau:
    Thanks a lot for the information.
    It is a metal detector ...but for a musical instrument.
    On your Coil/Inductor reader you used a Schmith trigger IC and then a Binary counter. Can we go directly from the 74HCT14 and 'count' that signal with the Stamp II?
    edited 2005-11-10 19:42
    Theremin maybe?....
    Jon Williams
    edited 2005-11-10 19:44
    prprog,
    This circuit was designed a few years ago, when there was only one BS2 option.
    Even so, the frequency from the 74HC14 is going to be a couple of MHz... I don't
    think a newer BS2 by itself will be fast enough. The 4040B brings the frequency
    down to a workable level for the BS2.
    Note: Use a 74HC14 rather than a 74HCT14... The difference is in the input, one
    is TTL level and the other is CMOS level. The "non" TTL produces more of a
    square wave on the output.
    Question:
    Are you trying to detect a string vibration such as that on an electric guitar?
    Beau Schwabe
    IC Layout Engineer
    edited 2005-11-10 20:13
    Hi John/Beau:
    Very clever. Well sort of a theremin. I just got some information on the workings of an instrument built by Thermen. It was called the theremin cello. It works by inductance changes in a coil. So my idea is to built this electronic instrument and interface to the Stamp II and translate those values to MIDI (which I have done before)-> a MIDI theremin cello (or violin or bass).
    The "coil" will be a very (very) long coil.(representing the string of the instrument)[noparse][[/noparse]maybe the metal string of guitar or electric bass might work] The Inductance changes will be done by touching the coil at certain points. Luckily this changes can be translate to a frequency (from the 74HC14) and read by the STAMP II.
    edited 2005-11-10 20:29
    prprog,
    With the subject of coils and inductors, you actually caught me at a good time.
    On the side (when my electrical checks in layout are running) I am currently working
    on an application with a new design approach that senses the inductance changes
    in a coil. ... So basically inductors are fresh in my mind at the moment.
    May I ask how long is "very (very) long" and how exactly will you be
    "touching the coil at certain points"?
    Beau Schwabe
    IC Layout Engineer
    edited 2005-11-10 20:36
    Beau:
    Lets say a 30 inches long coil (it will be a plastic (?) tube wound with copper wire. The contact will be done with a very flexible wire (or wire mesh).
    edited 2005-11-10 22:38
    Just out of curiosity have you seen this page: http://www.thereminworld.com/news.asp?cat=31
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
    edited 2005-11-10 22:44
    Oh, and here's a complete construction article including schematics from that first link.· In any event I bet an SX could easily be implemented into this system...· =)
    Chris Savage
    edited 2005-11-10 23:01
    This may be a weekend project....
    My first thought is that a 30 inch coil would have a really large inductance value.
    ...looking at a few things around here that I could build one of these with.
    1" PVC pipe
    large spool of #22 insulated solid hook up wire
    ....Hmmm ok so the PVC actually has a diameter of 1-1/8" and at a rough estimate
    the #22 wire with insulation has a pitch of 18 turns per inch.
    18 turns per inch at 30 inches equals 540 total turns with a mean radius of 0.5625 inches.
    Reference (inductance calculator):
    http://forums.parallax.com/showthread.php?p=557406
    See "CoilCalc_XLS.txt"
    for a "single layer wound air coil"
    L = ( ( r * N ) ^2 ) / ( ( 9 * r ) + ( 10 * l ) )
    where:
    r = the mean radius (inches)
    N = number of turns
    l = length (inches)
    For L, I get about 300uH
    Reference (Resonant Frequency Calculator)
    www.deephaven.co.uk/lc.html
    ...Use this to play with various capacitor values.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-11-10 23:14
    prprog,
    I just caught something in your post that I should point out....
    "The Inductance changes will be done by touching the coil at certain points"
    In a tuned LC when you touch the coil what you are changing more
    than inductance is the capacitance. Unless you are made of metal, touching
    the coil has very little effect on the actual inductance value.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-11-11 00:25
    Note: Beau has a thing for PVC pipe and coils.· I don't know what that tells you, but he does know his coils!· =)
    Chris Savage
    edited 2005-11-11 00:36
    Yes the flexible metal strip will be touching the wire wound pipe (the coil) at certain point. If the flexible metal strip is connected to the circuit, then will it change the coil length (at the moment of contact) and change the inductance ?
    Again·thank you·(to ALL) for your help.
    edited 2005-11-11 00:38
    Chris,
    Hmmmm
    Beau Schwabe
    IC Layout Engineer
    edited 2005-11-11 00:40
    In all seriousness...Beau knows his stuff!· But I couldn't resist...So, hopefully you guys will work something out that we can all learn from?· =)
    Chris Savage
    edited 2005-11-12 05:50
    prprog,
    Based on my earlier calculation that a 30 inch coil with 540 turns
    of #22 solid insulated hookup wire wrapped around a 1 inch PVC
    would yield an inductor of about 300uH, here is an idea that might
    be more effective than trying to measure subtle inductive changes.
    At the risk of sounding like Nicola Tesla, you can apply the basic
    principle to your coil that applies to a Tesla coil.
     In >----o----[noparse][[/noparse]Coil]----o----> Out
           [noparse][[/noparse]Cap]          [noparse][[/noparse]Cap]
    GND >----o--------------o----> GND
    With a Coil value of 300uH and Capacitor values of .1uF
    (something easy to find) the resonate frequency is going to be
    about 29kHz.
    Note: In the schematic above In and Out can be interchanged.
    Now, if the circuit is in tune and you apply a 1V p-p sine wave
    at the input that has a frequency of 29kHz the voltage potential
    between the Input and the Output can be in excess of 250V p-p!!!!
    Keep in mind that this voltage is without any kind of load and is
    very low current, it is however still present.
    Now you say, how can I apply this to my project....
    Well, when you "touch" the coil at various locations ( as you indicated
    you will have a wand of sorts... this is actually perfect). you effectively
    create a voltage divider with the coil. What's nice is that you don't
    need to be in direct contact with the coil windings, the capacitance
    between the insulation on the coil windings and your "wand" will be
    enough so that you should be able to get a voltage reading between
    the "wand" and ground. By loading the Input an Output with a resistor
    ( Start in Meg Ohm range ) you can bring down the voltage potential
    to a more manageable level. ...Or you can slightly detune your coil by
    changing the input frequency. You will want the input frequency to be
    adjustable anyway.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-11-14 05:17
    Calculated Inductance: 300uH
    Actual Inductance: 325uH
    I changed the capacitor values from 0.1uF to 220pF. This increased
    the resonate frequency to about 595kHz. With the circuit below, I
    measured about 100V directly across the coil. When measuring with
    the "wand" to GND I measured a proportional voltage from 35V down
    to 0V depending on where the "wand" was on the coil.
    Tuning:
    By placing my hand on the "high-side" of the coil, I tuned the variable
    resistor, looking at the scope, until the voltage level peaked and was
    stable. (About 100V Pk-Pk)
    Beau Schwabe
    IC Layout Engineer
    937 x 537 - 33K
    edited 2005-11-14 12:54
    W o w !!! Thanks a lot !!!!.
    I will have to try this myself as soon as possible.
    Question: You apply a sine wave signal to the coil/capacitor section. Will it work without such signal or by applying the +5v ?
    I read thru your notes about voltage of 100v to 35v. I am only a novice on electronics but for sure this will kill the Basic Stamp right away. Some kind of optoisolator might be in order. Right? (even using resistors as you point out - the voltage potential is there so an error will be a disaster)
    prprog,
    you said...
    A sine wave is ideal, but a square or triangle will also work. ....at 595kHz off of a 74HC14, a square wave almost
    looks like a sine wave.
    you said...
    100v is what you see directly across the coil...35V is what is capacitively coupled through the coil to the "wand" without actually touching the coil.
    What I used for a "wand" was to connect the wand terminal to my thumb like a ring, and then I used my entire
    hand to wrap around the coil as if holding a tennis racket. By moving my hand back and forth applying various
    amounts of pressure on the coil, I could predictably change the output voltage.
    you said...
    This is relatively low current (less than 3mA @ 35V) .... I have added a circuit to condition the output
    so that an ordinary ADC, or a scheme similar to that used in my Stamp based metal detector should be able
    to read the voltage without any problems.
    Beau Schwabe
    IC Layout Engineer
    959 x 545 - 43K
