M-Sorter Question
My question has to do with the placement of the 'rotor plate' relative to the servo...
I followed the directions and attached the rotor plate to the servo 'x' coupler and placed into the·assembly so that just a little bit of the far right slot of showing, but when I run the source code from Parallax the rotor arm bangs in to the TOA sensor standoff a bit.· And the indexing movement does seem to put an M&M under the sensor in time with the LED strobes...
I·tried indexing the rotator plate counter clockwise and recoupled to the servo, but one 'tooth' on the servo seems to be too much and doesn't look like an M&M could fall out when I do this.
I studied the video on the website, and it doesn't appear that the rotor plate is hitting the sensor standoff at all.· Any advise on the best placement of the plate?· If I removed the 'X' servo coupler and index 90 degrees, would I perhaps have a better alighment ?
Hopefully my desciption is clear enough.
Thanks for any help!
Post Edited (Piper984) : 11/10/2005 2:44:44 PM GMT
·· All servos have some variance in them.· You cannot always use the same code on one system as the next.· Often you must make minor adjustments to compensate for servo variances.· Adjust your numbers so the servo moves where it should.· Most people using this will have to make minor adjustments to the code.· You can also try the code from the following page (See the links from the contest).· There are codes that will allow you to calibrate the servo in one of the entries.
http://www.parallax.com/detail.asp?product_id=30067
Chris Savage
Parallax Tech Support
csavage@parallax.com
Chris Savage
