Use BS2P As Voltage Meter and Amp Meter
Hello,
I want to·use BS2P·measure·low·voltage·range 0-5 Volt by·milivolt and Display on basic 16x2 LCD
From·BS2P manual there·are·circuit sample using ADC0831 (National semiconductor) 8-Bit Serial A/D
Would this IC suit for my project? On National website there are also 10-Bit 12-Bit A/D
How to choose the suitable IC.
And if I want to measure the current (mA) is it simple like to use one resistance connected parallel with
this volt measure then calculate by I=V/R ?
Please give me some suggestion if there are better A/D IC and also Current measuring method
If you can post me some good links it would be a great.
Thank you.
Duke..
Thank you.
Duke..
If you're looking for resolution in the 10mv-per-division range, the AD0831 will do fine.
The device will measure 0 to 5v. Not sure what current range you're looking to
measure, but by use of an appropriate shunt resistance you can define any current
range you desire...keeping in mind the resolution limitation.
"And if I want to measure the current (mA) is it simple like to use one resistance connected parallel with
this volt measure then calculate by I=V/R ?"
Correct.
Should you need a wider sampling range, consider the 10 and 12-bit ADCs, as you
have noted previously.
Tracy Allen
www.emesystems.com
If I want to measure 4 channels voltage can I use IC in the series with AD0831
and will I get all channels data at the same time.
Duke..
