Need help with Phone Line interface with a BS2P-40.
Hello all, I have built the phone line interface as shown on page 169 of the Basic stamp ref. manual. I am running a program that brings in the relay and from there I get a dial tone. I have a telephone handset and can monitor the touch tones being generated and the called party picking up the line on the receiving end. My problem is this, the wrong touch tones are being interpeted on the receiving end at times and it calls some unfortunate being
The line does not seem to have any noise on it and my computer does not have any problem makng a connection on-line.
Does anyone have experience with this and maybe recommend a filter circuit or something that might help ?
JMLStamp2p
P.S. I am using a BS2P-40 on a PDB board with the built-in RJ-11 jack ...
JMLStamp2p
·· Just to confirm, do you·have the jumper blocks removed from the RJ-11 jack on the PDB?
Chris Savage
Parallax Tech Support
csavage@parallax.com
Chris, I have checked to see if the tones are consistant and they are not. When I have it dial a certain number the tones are generated correctly maybe 2 out of 10 times. For some reason it seems to output the higher tones correctly more-so than the lower tones. I have checked this by monitoring the calls in my area wich is (839). It doesn't seem to be effected much unless the tones are closer togather.
My computer is not effected at all even though the modem dials tones quickly.
JMLStamp2p
Chris Savage
