I'm sorry...
I need some hand-holding...
I have read that serial ports logic 1 is -3 to -25 volts and that logic 0 is +3 to +25 volts and I just might have that backwards.· I want to interface an SX to a PC serial port so I can watch pretty characters come up in hyperterminal.· This would be through a Parallax-sold USB-to-serial adapter.· What voltages do I need to worry about?· Do·I NEED this MAX232 thingie?· Yes, I did a forum search for "RS-232", and "pc serial port".
http://www.parallax.com/detail.asp?product_id=29120
Chris Savage
Parallax Tech Support
csavage@parallax.com
http://www.parallax.com/detail.asp?product_id=28024
Jon Williams
·· The Caps are used for the charge pumps.· I'm not certain what would happen, but if you're going to experiment, then by all means, experiment.·
Chris Savage
Jon Williams
