I'm sorry... — Parallax Forums
I'm sorry...
Lord SteveLord Steve Posts: 206
edited 2005-11-01 16:54 in General Discussion
I need some hand-holding...
I have read that serial ports logic 1 is -3 to -25 volts and that logic 0 is +3 to +25 volts and I just might have that backwards.· I want to interface an SX to a PC serial port so I can watch pretty characters come up in hyperterminal.· This would be through a Parallax-sold USB-to-serial adapter.· What voltages do I need to worry about?· Do·I NEED this MAX232 thingie?· Yes, I did a forum search for "RS-232", and "pc serial port".
    edited 2005-10-29 18:13
    MAX232 is the simplest way to go.· See details on our RS-232 AppMod, as the same concepts apply to the SX.
    http://www.parallax.com/detail.asp?product_id=29120
    csavage@parallax.com
    edited 2005-10-30 00:30
    Since my serial port is tied up with the SX-Key, I usually use the USB2SER adapter for SX to PC comms.
    http://www.parallax.com/detail.asp?product_id=28024
    Jon Williams
  • Lord SteveLord Steve Posts: 206
    edited 2005-11-01 16:38
    I have secured a MAX232.· It is NOT a MAX232A.· I only have 10uF electrolytic caps.· The datasheet says 1uF caps.· Can I use the 10uF caps, and if so, what behavior can i expect?
    edited 2005-11-01 16:46
    Steve,
    ·· The Caps are used for the charge pumps.· I'm not certain what would happen, but if you're going to experiment, then by all means, experiment.· =)
    I'm pretty sure you need to use 1 uF caps -- that said, you can try the 10 uF but if they don't work you know why.
    Jon Williams
