HDSP2111 smart Alphanumric display
·Has any one ever used the HDSP2111· smart Alphanumric display
with a basic stamp, I have seen some things on·256 ASCII· but not on·128 ASCII. I would like to use for display on curent project but cant find any similar projects using this kind of display. will attach the spec sheet. Thanks David
·1+1=10
ABC and 123 really account for 26 and 10 characters respectively. You have a lot of extra bytes to fool with. Even if you have Capital and Lower Case chracters, you only come up with 56 without punctuation, special brakets, line drawing, unprintable control codes, etc.
As I understand it, the original ASCII was 128 and only required 7 bits of a byte. The other bit was used for parity checking. With the extension to 256, in one version many European characters were included and in a second version the Japanese phonetic characters were included.
By the way, IBM chose to use its own EBDIC as an alternative set. One might consider this a primative encoding to hide information. I think it started as 128 bytes too.
Now with GUI, we have gone to Unicode to allow Chinese, Japanese, Korean and other character based languages. Each charcter used a two byte or 16 bit word. In this way, the 7000 individual characters that Chinese requires are each assigned a unique code. But, ASCII is still included as a subset.
PS the hdsp is not serial, just a different series of the same type of display.
·1+1=10
