Vdd vs Vin - What are they specifically.
I have a BOE-BOT Board of Education (rev C) microcontroller stamp board which has a Vdd jumper and a Vin jumper. I currently use a 5vdc - 2A (what luck!)·P/S·from an unused Linsys Printer Server.
I can connect the 5 vdc power supply·to the board and it doesn't matter·if I put the jumper on Vdd or Vin. However, I also have connection for a 9VDC battery on the board or could also use·the ·4 AA battery pack (which BTW - mine came wired backwards - so I just put the batteries in backwards which works - Radio Shack wanted me to bring the entire BOE-BOT back in for a simple part replacement - not worth it to me).
Anyway, where does the 4 AA battery pack plug into go and where does the 9 vdc battery go - Vdd or Vin?
Does Vin refer the the pin on the BS2 going to the on chip 5v regulator or is that Vdd?
For now it is not a problem as I get anywheres between 5.15vdc and 4.93vdc depending where I am measureing the 5vdc Linksys power supply.
I·also·wanted to know what I should use if take the BS2 off the Board of Education rev C board and place it onto a breadboard using a 7805 or not (what voltage limits do I have - assuming I'm not using the Linksys 5vdc power supply and something higher like 12 vdc for example).
Thanks for answering my·questions as I know I always get great support on this site.
Timothy Gilmore·
Timothy Gilmore·
If you're running 5V to VDD (i.e. your Linsys 5V, 2A) then·be sure and check that it's really 5V.· Most wall-warts, &c. aren't regulated and that one might be 5V at 2A and a much higher voltage at lower current/s.
Happy Halloween!
Ryan
Ryan Clarke
Parallax Tech Support
RClarke@Parallax.com
