Working with HEXCRAWLER
Pls Inform me the Persons who r working with hexcrawler..i want·some codeing information about Hexcrawler SEROUT/SERIN Command, And Also the TX,RX how to Communicate each other, and how DATA[noparse][[/noparse]Distance show],coming from Remote Transmitter has receved and show it Serialy conncted PC monitor with the "DEBUG" command.
Pls help me,
I alredy done the transmison portion but i cant get the DATA Receive,from the other end Pls help me.
Pls help me,
Dave
Dave Andreae
Tech Support
dandreae@parallax.com
Http://www.parallax.com
One question is that is it possible can i use two debug terminal is shown into the same window terminal if yes then please give me the code.
I want to transfer the data through wireless Dual Mode RF Module 27988
Transceiver(433 MHz) when i give a command in the first debug terminal "D(display sonar)" the serial conncted debug terminal give me the Output data that he gets through wirelessly from the sonar.i.e in Debug terminal it shows that.
S3 SRF04 distance test
Raw Distance
Inches........
Centimeters.
like that...
Code:
S3_display:
· temp = rawDist/74
· DEBUG CLS, "S3 SRF04 distance test",CR,
······· "Raw Distance..", DEC rawDist,CR
· DEBUG "Inches........", DEC temp,CR
· temp = rawDist/29
· DEBUG "Centimeters...", DEC temp,CR
· SELECT selectedMode
··· CASE $01
····· DEBUG "Mode = Left(", HEX selectedMode,")",CR,
··········· "Left raw dist = ",DEC distReading(0),CR,"Right raw dist = ",DEC distReading(1)
··· CASE $02
····· DEBUG "Mode = Right(", HEX selectedMode,")",CR,
··· CASE $10
····· DEBUG "Mode = Forward(", HEX selectedMode,")"
··· CASE $40
····· DEBUG "Mode = Backup(",HEX selectedMode,")"
·· ENDSELECT
·· PAUSE 1000
RETURN
this is a small portion i want to tranmited pls help me.
Post Edited (tribeni) : 11/7/2005 11:42:02 AM GMT
