I Bought Transistors, And don't Know How To Wire Them! — Parallax Forums
JimmioJimmio Posts: 43
edited 2005-10-26 15:20 in BASIC Stamp
Help If You Can. I bought the 276-1604 from radio shack. 2n3906 PNP. it says that pin1: emitter (meaning Out?)pin2:base(possibly +?) and pin3: collector (?) I'm trying to wire a 9v motor to the basic stamp. Thx in advance, Jimmio
Info on all kinds of robosports:
www.freewebs.com/robotbattles
    edited 2005-10-26 01:20
    This will help: http://www.parallax.com/dl/docs/cols/nv/vol1/col/nv6.pdf
    Jon Williams
  • JimmioJimmio Posts: 43
    edited 2005-10-26 01:52
    Can Transistors be used as an amplifier? I need to get the little Piezo Speaker Louder. Could You Help Me? Thx in advance, Jimmio
    edited 2005-10-26 01:56
    Jimmio, you really could benefit from a basic course in electronics. Give "Getting Started in Electronics" by Forrest M Mims at try.
    Jon Williams
    edited 2005-10-26 03:09
    I'm only 12. So, could you please help me anyway?
  • FlyingFishFingerFlyingFishFinger Posts: 461
    edited 2005-10-26 04:21
    Wow 12...-I'm 15.
    Sure we can help.
    For a start, did you get the motor running with the article Jon gave you?
    If yes good, if not, let us know.
    For your piezo speaker, yes, one can use a transistor as an amplifier, in fact that's one common use in very simple amlifiers. How is it connected now (incl. voltages)? Once we know that, we'll help you deal with it.
    Just a suggestion: Judging by your posts, it may be easier to get one thing straight at a time.
    Rafael
    Jimmio,
    For reasons I have mentioned in a previous posts, you probably do not want to use a PNP with a 9V supply as your motor indicated
    because the transistor will always be "ON". A NPN transistor would have been a better choice when using different voltage supplies.
    That's not to say that you can't use a PNP, just don't go over 5V.
    Reference:
    http://forums.parallax.com/showthread.php?p=552072
    http://forums.parallax.com/showthread.php?p=538838
    http://forums.parallax.com/attachment.php?attachmentid=37701
    Beau Schwabe
    IC Layout Engineer
