Expanding Inputs from "StampWorks"
Hi,
I am reading the "Experiment #24b: Expanding Inputs" from "StampWorks', using the shift registers.
I'm having a problem understanding how the program will determine the state of each individual switch. Does it just determine whether any switch is on or off, or does the program determine the state of each individual switch?
I need something like this:
If switch #1 is on then serout [noparse][[/noparse]this]
If switch #2 is on then serout [noparse][[/noparse]that]
etc. (for 24 sensors, so I will need 3 shift reg. IC's)
Thanks for any suggestions.
Tony A
Post Edited (TonyA) : 10/23/2005 1:34:47 PM GMT
Tony A
· IF (status1.BIT0 = 1) THEN
··· SEROUT TX, Baud, [noparse][[/noparse]"Button 1 pressed", CR]
· ENDIF
Jon Williams
Tony A
