Expanding Inputs from "StampWorks" — Parallax Forums
TonyATonyA Posts: 226
edited 2005-10-23 14:58 in BASIC Stamp
I am reading the "Experiment #24b: Expanding Inputs" from "StampWorks', using the shift registers.
I'm having a problem understanding how the program will determine the state of each individual switch. Does it just determine whether any switch is on or off, or does the program determine the state of each individual switch?
I need something like this:
If switch #1 is on then serout [noparse][[/noparse]this]
If switch #2 is on then serout [noparse][[/noparse]that]
etc. (for 24 sensors, so I will need 3 shift reg. IC's)
Thanks for any suggestions.
Tony A
Post Edited (TonyA) : 10/23/2005 1:34:47 PM GMT
    edited 2005-10-23 14:55
    Remember that every variable in PBASIC is bit-addressable, so you can do something like this after you read a·value back from the 74HC165:
    · IF (status1.BIT0 = 1) THEN
    ··· SEROUT TX, Baud, [noparse][[/noparse]"Button 1 pressed", CR]
    · ENDIF
    Jon Williams
  • TonyATonyA Posts: 226
    Very cool, thanks.
    Tony A
