SureLink radios
· Hello all,
··· For a remote Stamp-based data logger I'm using a set of SureLink data radios. Overall I've been quite pleased with them, particularly their Stamp friendly interface.
··· I transmit a string of about 130 characters every·8 seconds or so. Contained in the string are 2 12-bit analog values, dissolved oxygen %, salinity, time date, depth, latitude, longitude, and speed as calculated by the GPS.
·· I've set RF baud rate to 4800 and the data goes at 2400.
·· Just wanted to compare notes with anyone else's experience, particularly data rates and ranges in open areas versus built-up areas using the on board antenna compared to an external.
·Cheers
·Tom Sisk
·Cheers
·Tom Sisk
Tim
Thanks for saying hi.
If you happen to be near me in eastern Canada, I've got a spare set of SureLinks you could try!
Cheers,
Tom
DTQ
Your offer is very generous. I'm on the west coast in Washington, north of Seattle..... Truth is, my time is so short these days that I wouldn't have time to work with the radios right now, so I'd better wait until that changes some.
Thank you very much,
Tim
