Pwmpal question — Parallax Forums
Pwmpal question
TiboTibo Posts: 81
edited 2005-10-17 11:56 in BASIC Stamp
Hello all,
I want to drive the 'Cybot' H-Bridge using a PWMPAL.
My question is :
In order to save some I/O ont my BS2e (not OEM, standart), can I use the PWMPAL alone (not under the BasicStamp, but side by side), and if yes what wiring shall I do ?
Ialready thought of natural answer : if not used all I/O of the PAL are set as inputs...BUT shakehead.gif this does not solve my lack of I/O ont he stamp since I'd like to use 4 of the PAL output AND all the stamp I/O.
So i'd wire only the P0 pin from the Stamp to the PWMPAL, but I dont know about power and electrical issues... confused.gif
Can you help ?
Thank you
Post Edited (Tibot) : 10/10/2005 8:24:08 AM GMT
  • TiboTibo Posts: 81
    edited 2005-10-10 12:51
    Aarg, nobody knows and I cant find the information on the parallax web site [noparse]:([/noparse]
    Nobody ever took the PWMPAL aside from the BasicStamp ?
    edited 2005-10-11 03:43
    Yes, you should be able to run the PWMPAL on its own, only with the following physical connections:
    pin 5 to pin 5 (p0 for data)
    pin 4 to pin 4 (Vss, ground)
    pin 23 to pin 23 (Vss, ground)
    pin 21 to pin 21 (Vdd, +5 volts)
    The connections to Vss and Vdd would not have to be made right on the corresponding Stamp pins. You could find those voltages elsewhere in your system.
    Tracy Allen
    www.emesystems.com
    edited 2005-10-11 11:22
    hop.gif·cool !
    Thank you Tracy !
    edited 2005-10-16 00:05
    I tried, re-tried, did a first pcb, then a second...then I checked if pwmpal was not dead ( wink.gif ) wasn't.
    Dont you think it needs the Vin(p13) pin connected also ?
    Thank you !
    edited 2005-10-16 00:34
    I haven't used the PWMPAL in a long time so I had to go hunting for one -- and I have good news.
    First, you're using the PWMPAL differently than we designed it, so be very careful.· Next, you need to make these connections:
    - Vdd
    - Vss
    - Rst
    - Sio
    The attached diagram shows where the connections are on the PWMPAL.· I suspect you neglected the RST line and I confirmed that if this is not connected (I popped my PWMPAL into the breadboard of a PDB) then there is no communication between the devices.· Note that any of the pins on the PWMPAL that have no names are just blank sockets.
    Jon Williams
    291 x 412 - 42K
    edited 2005-10-16 02:02
    As you noticed, electonic is new to me and for now I'm practicing ironing, pcb'ing and patience roll.gif !
    Thank you for the hunt Jon , I really appreciate the time and energy you spend supporting us. tongue.gif
    edited 2005-10-16 03:04
    A (probably) last question to make sure : idea.gif can I let the RESET pin of the PWMAL floating ? Or do is it mandatory to connect it with the RESET pin of the BS2e ?
    Thank you.
    edited 2005-10-16 03:11
    If you let it float, it won't work -- I mentioned that earlier. Since you're new (you said so), I suggest you stop *cheating* (or trying to) and make the connections as they are designed to be made; that will eliminate any further troubles.
    Connect: Vdd, Vss, Rst, and Sio to the BASIC Stamp so that the software demos we provide will work. And you'll be on to writing code instead of troubleshooting hardware -- that's much more fun!
    Jon Williams
    I already followed your initial advise (stop *cheating* (or trying to) and make the connections as they are designed to be made) but i got short on free pin....this is why all this *cheating*.
    Thank for all Jon !
