code for DCmotor speed control
i wanted to design a model using BS2 for controlling the speed of DC motor
i want the specification of the motor to be used with the BS2 and if possible
give some suggestion in type of circuit to build , type of pulse width modulator
pavan
pavan
Well, almost any DC motor can be used with BS2.
The specifications you need depend neither on the BS2 nor actually ont the motors, since you want to drive your DC motor with a transistor or an h-bridge...What you need to know is :
What kind of transistors or H-Bridge can be use with BS2 and drive the DC motors I choosed knowing the model design, weight, needed speed and acceleration ?
There are many examples of DC motor drivers on the net and, remember, google is your friend [noparse];)[/noparse]
Try this :
youre welcome...
Jon Williams
