code for DCmotor speed control — Parallax Forums
romanroman Posts: 3
edited 2005-10-15 14:57 in BASIC Stamp
i wanted to design a model using BS2 for controlling the speed of DC motor
i want the specification of the motor to be used with the BS2 and if possible
give some suggestion in type of circuit to build , type of pulse width modulator
pavan
  • TiboTibo Posts: 81
    edited 2005-10-15 14:54
    Pavan, nono.gif you want nothing nono.gif , you kindly ask for helpyeah.gif ....dont you? shocked.gif
    Well, almost any DC motor can be used with BS2.
    The specifications you need depend neither on the BS2 nor actually ont the motors, since you want to drive your DC motor with a transistor or an h-bridge...What you need to know is :
    What kind of transistors or H-Bridge can be use with BS2 and drive the DC motors I choosed knowing the model design, weight, needed speed and acceleration ?
    There are many examples of DC motor drivers on the net and, remember, google is your friend [noparse];)[/noparse]
    Try this :
    What size motor do you need for your model? Knowing that you can select an appropriate motor controller from a multitude of choices.
    Jon Williams
