what to use...what to use...
I would like to replace a basic stamp with something smaller and cheaper to controll a IR LED in a space a bit too small for a stamp to fit. Im guessing I would need a PIC but your the knowledgable ones so you tell me
~Jeremy
~Jeremy
Jon Williams
thanks
~Jeremy
Jon Williams
You could use the BS1, I understand that is smaller than a BS2. You'll probably still need a 555 timer to generate the 38 Khz wave, that the BS1 can then modulate to make the 'bit' pattern of a remote.
The PIC's start at under $1 each for small 8-pin units you could use for controllers. The learning curve is pretty deep but the execution speed is much higher than a Stamp.
My robots us Stamps for central controllers and small PIC's for ancillary units like IR sensing and servo or dc motor control. Communication is based on the Stamp's marvelous serial commands.
Jon Williams
·1+1=10
