Opening PFD files
Hi I am having a small problem with the forum. Anytime I try to open a pfd file that is in the atttachment area of a posting I get an error message saying file could not be found. Any ideas how to go about opening the files?
Thanks David Warren
Thanks David Warren
Jon Williams
Thanks David Warren
Jon Williams
My first guess would be that when you installed the latest version of Acrobat, it got put in a different place than the old one occupied, or the name changed, and your registry did not get updated for your web browser. In essence, your browser has a "helper application" defined for opening files of type "pdf" and it can't find that application. Findong where those "helper applications" are defined in your browser and making sure that the "pdf" handler is pointing to the right place would probably be my first step. If that doesn't help, I'd re-install Acrobat.
(The reason I'd look at the browser first, is because you said that "Save As" works. That would indicate to me that your "OS-level" file associations are correct).
Truly Understand the Fundamentals and the Path will be so much easier...
