Pwmpal question
Hello all,
I want to drive the 'Cybot' H-Bridge using a PWMPAL.
My question is :
In order to save some I/O ont my BS2e (not OEM, standart), can I use the PWMPAL alone (not under the BasicStamp, but side by side), and if yes what wiring shall I do ?
Ialready thought of natural answer : if not used all I/O of the PAL are set as inputs...BUT
this does not solve my lack of I/O ont he stamp since I'd like to use 4 of the PAL output AND all the stamp I/O.
So i'd wire only the P0 pin from the Stamp to the PWMPAL, but I dont know about power and electrical issues...
Can you help ?
Thank you
Post Edited (Tibot) : 10/10/2005 8:24:08 AM GMT
My question is :
Can you help ?
Thank you
Nobody ever took the PWMPAL aside from the BasicStamp ?
pin 5 to pin 5 (p0 for data)
pin 4 to pin 4 (Vss, ground)
pin 23 to pin 23 (Vss, ground)
pin 21 to pin 21 (Vdd, +5 volts)
The connections to Vss and Vdd would not have to be made right on the corresponding Stamp pins. You could find those voltages elsewhere in your system.
Tracy Allen
www.emesystems.com
Thank you Tracy !
I tried, re-tried, did a first pcb, then a second...then I checked if pwmpal was not dead (
Can't make it run side to side to the BS2...
Dont you think it needs the Vin(p13) pin connected also ?
Thank you !
First, you're using the PWMPAL differently than we designed it, so be very careful.· Next, you need to make these connections:
- Vdd
- Vss
- Rst
- Sio
The attached diagram shows where the connections are on the PWMPAL.· I suspect you neglected the RST line and I confirmed that if this is not connected (I popped my PWMPAL into the breadboard of a PDB) then there is no communication between the devices.· Note that any of the pins on the PWMPAL that have no names are just blank sockets.
Jon Williams
Thank you for the hunt Jon , I really appreciate the time and energy you spend supporting us.
Thank you.
Connect: Vdd, Vss, Rst, and Sio to the BASIC Stamp so that the software demos we provide will work. And you'll be on to writing code instead of troubleshooting hardware -- that's much more fun!
Jon Williams
Thank for all Jon !
