BOE-USB, OS X 10.4.2, FTDI Drivers
Hello,
I've installed the FTDI drivers for the boe-usb, and cannot establish a connection with my stamp. I have checked my system profile and can see that it recognizes the Usb-serial extension under USB. I'm not being prompted with a new port when I enter network preferences and I don't see a new entry for the .kext file when I check the /library/extensions folder. All of this would make you think that the stamp is fried, but it works fine on a friends x86 machine. I have the newest version of macbs2, the new versions of the USBSerialDriver from FTDI, and a fairly vanilla install of tiger( no funny haxies). Can someone please help me? I really need this to run on my lil' tiger and it's starting to make me
I have a BOEusb Rev B running just fine under Mac OSX 10.4.2 G4 1.33 GHz Powerbook G4. Current version of MacBS2 is 2.0b12b and it shows usbserial-1B1 under the serial port pull down menu.
Do you see the port in your menu?
What machine are you attempting to access the BOE from; is it a G4 or G5 based machine. As of this posting I don't recall trying it on any of my G5 machines. I will check and post what I find.
Have you tried a clean install of 10.4.2?
Doc
It works fine under OS 10.4.2 on a dual 2.0 GHz Powermac G5 too. Thas was with MacBS2 2.0b10 installed. I had to install the FTDI drivers but that was very strait foward. I installed FTDIUSBSerialDriver v 1.09 which can be downloaded from the FTDI site.
After restart the port shows up in MacBS2 port list just fine. I did NOT even have to "bless" the driver by opening the netport configurations.
Have you checked your cable? Try a different one, perhaps that is an issue.
Doc
ON EDIT:
It also works fine on 2.0 GHz iMac G5, also running OS 10.4.2. This was a fresh install of MacBs2 2.0b12 and FTDIUSBSerialDriver v2.01 from the above linked site and everything works as expected.
Logic would indicate since your BOE works under an older version of OS installed and on a friends PC then it's not the board. I suspect you have conflicts on your current OS installation. Do a clean install and start over.
Cheers
Post Edited (doggiedoc) : 10/9/2005 2:20:06 PM GMT
Thanks for all the input. I'm beginning to think a fresh install is the way to go, which is kind of annoying, however I'll give it a shot. BTW, where is version 1.09 of the driver. I've been searching through FTDI's site and have only found v 2.01. Perhaps I should try a different version before I proceed.
Thanks again,
Chris
Forrest is right. Try the things he suggested first.
v1.09 is an old installer I had handy. The current version (2.01) should be your better shot at compatibility.
Doc
