basic stamp turns off after programming from laptop serial port?
anyone have this problem? I usually program on my imac via a usb to serial converter but after attempting to program from an old dell 3800 laptop via serial cable it turns off. hmm. it gets the program but i need to unplug the serial from the board of education to get it going again. any info would be greatly appreciated.
John
John
If you're speaking of the Stamp "turning off", how are you differentiating between the Stamp being "turned on" and it being "turned off"? Are you implying that you can not program the Stamp from the Dell laptop system? Which operating system are you using on the laptop?
Bruce Bates
Steve
"Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
Chris Savage
Parallax Tech Support
csavage@parallax.com
Thanks again.
p.s. I'm using the cable that came with the homework board which worked fine on my mac.
·· I know of no known work-around for that problem.· It's related to the computer, not the BASIC Stamp or the Editor software.· It's definately a hardware problem.· If you have a USB-to-Serial cable that worked on the Mac, it should work on the PC.· What brand is it?
Chris Savage
Chris Savage
