problem building an OEM BS2p40
I'm trying to build the BS2p40 on a custom design.· Using the schematic from this link
http://www.parallax.com/dl/docs/prod/schem/bs2p40SchemRevB.pdf
I tried to build one using these parts from parallax
PBASIC INTERPRETER CHIPS
PBASIC48W/P40
EEPROM
602-00013
RESONATORS
250-12060
also, for the PNP and NPN transistor pack, I used
DDTA114ECA
DDC114EU
Then I used the Basic Stamp Editor v. 2.2, go to run, identify and it doesn't detect it.
I get
Loopback: Yes
Echo: Yes
but nothing under Device Type nor version.
The software and cable works correctly because it can detect the Basic Stamp kit I bought, but not the one that was just designed.
Attached is my schematic.· Can anyone tell me if I'm using a wrong part number or if my design is flawed?· Thanks.
PBASIC48W/P40
EEPROM
602-00013
RESONATORS
250-12060
DDTA114ECA
DDC114EU
I get
Loopback: Yes
Echo: Yes
Any help would be very much appreciated.
Jon Millard
I see a resitor of 10k across the resonator, to my feeling that resistor may be a bit larger 1M, or so.
Klaus
Tracy Allen
www.emesystems.com
Jason
He who dies with the most toys wins!
·· I believe the schematic is correct, but I will verify it with one of our engineers and post back.
Chris Savage
Parallax Tech Support
csavage@parallax.com
·· I confirmed today that we are, in fact, using the 10K resistors on the BS2p40 modules.· The schematic is correct.· If you're using a resonator purchased from us, the value is correct for it.
Chris Savage
