BS2 OEM Breadboard
When I got my BS2 OEM kit, instead of the 20-pin header that came with it, I installed a 20-pos female header -· has the little pin sockets just like a machine collect DIP, except slightly larger in diameter.· I then designed a little plugin adapter that plugs into the female header, and added a Parallax breadboard on it - P/N 700-00012.· The adapter has a 10-pos header on each side of the breadboard, 16 I/O pins, 2 Vdd positions and 2 Vss positions.· Now I have a BS2 OEM BOE!!· I had to add an extra 20-pos header between the adapter and the BS2 so the adapter would clear the top edge of the DB9 connector.· And the whole thing takes up only half the space of the regular BS2 BOE.
(The company bugler will now play "Charge!")
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
Sid Weaver
·· Interesting contraption.· Are you going to call it the "Board Of Siducation"?··
Chris Savage
Parallax Tech Support
csavage@parallax.com
This sounds like a great idea. Please post a picture when you get a chance.
How did you provide for the connection to power? Does it have a power switch?
Russ
Thank you, sir.
Russell, there will be two wires·coming ·from the adapter for Vin and Vss.· My current plan it to patch them to a BOE or my PDB.
I'll post a picture when everythng is done.· My big problem right now is coming up with·labeling for the two 10-pos headers.
Sid
Sid
Cheers,
Doc
I for one like the name Board of Siducation
Thanks Chris for a good name for it
SAM
Sid
·· I'm glad you found a board setup you like.· As you can see, you've got more people interested in what you've done, so now you have to share.·
Chris Savage
BOS 5 is a top view.· I was going to lay it over the BS2, then decided to leave that area open, just in case.· That meant a little support for the free end.· You can see 2 bare pins - those are to patch in Vin and Vss.
BOS 2 is a bottom view.· You can see the extra header I had to add between the adapter and the BS2.· You can also see the little wooden support.
I'll make another tomorrow.· Have a couple of ideas to improve it.
Anyway, take a look.
Sid
Sid Weaver
Thank you for posting the pictures. The idea is worth considering.
Russ
It's underneath the BOS!· In spite of my earlier comments, I think I like this one better.· Takes up less real estate, and the connecting pins for Vin and Vss are in a more logical place.· I just push a 2-pos header on to the two pins.· The other end of the header cable has a connector that mates with a wall adapter.· I trimmed out the board a bit different and this time I was able to get labels on it. Seems like things always get a little bit better the second time around.
Sid
I·like this
Do you have any idea how much the·Board of Siducation·are going to cost
Please let us all know
THANKS
SAM
I guess I'll just wait and see if anyone expresses interest in having one.· If so, then we will work something out -· do they want just the board or do they want the·whole thing assembled.
Sid
I was just·talking about· the Board of Siducation· only
I built the BS2 un assembled and i could use a board just like that for testing
ideas that come to mind
THANKS
SAM
1 ea Breadboard· Parallax 700-00012
1 ea Header· SSW-120-01-S-S
1 ea Extender ESQ-120-13-S-S
2 ea Header SSW-110-01-S-S
1 each Strip Header TSW-120-16-G-S
Sid
So.......I made the following changes to the layout:
With the adapter laying over the BS2 OEM, all 16 I/O pins are available at a header on the right side of the little breadboard. Pin 0 is at the top, Pin
15 is at the bottom.· On the left side of the breadboard, top to bottom, there is a 12-pos header -· 4 Vdd, 4 Vss and 4 Vin.
I haven't made the new board yet.· It really stretches the vertical limits of my Super Mill.· The board requires a vertical dimension of 1.700 and the max travel of my Y table is 1.8125, so it will be close.· I'll post a picture if all goes well.
Sid
· I make cables using Molex "C-Grid" pins and connectors (available from Digi-Key) and route them to headers wired in parallel for multiple I/O pin access, it's like a reverse proto-board (having header pins instead of wire sockets.)· I can then patch in off-board circuits, switches, terminals, &c.
· In fact, I·use that proto-board patterned printed circuit board for this (I bought a bunch a long time ago, they may still be available at Radio Shack).· Similarly patterned boards would work just as well.
It actually worked out better than I thought it would.· The whole board is the same size as the original, and I think the porting of the I/O pins, plus 4 ports each for Vin, Vss and Vdd is a definite improvement.
I used 1.6 inches of travel on the Y table - I probably could have used 1.7.· So on my next board I'll see if I can make a board with a vertical requirement of 1.7.· X travel is no problem - I can probably go up to 3.75 or 4.0 inches.
Sid
Sid·······························································
This is very good idea with the right side of the board where you have all
the·Power·Pins and on the left side where all of the I\O pins are
SAM
