How do you find parts that you used on your board?
Hello Guys,
I have been messing around with Eagle Lite designing simple boards to learn how to use the software. I am now trying to find parts that the board design is using.
I have a parts catalog from Digikey.com but when trying to find the part that I used on one of my board designs, I cant find them! It is like trying to find a needle in a hay stack!
For example, I can't find·the following·connecter anywhere in the 1500+ page catalog.
Part#··L02P····· con-amp-mt····
Any suggestions?
Any suggestions?
·1+1=10
I have found some parts that are both in the library and the catalog I have. I will have to do research this way since I do not know how to make my own parts yet. I plan to get the book that explains how to use Eagle cad, and I'm sure it has a section on how to create parts.
Thanks again.
Go to www.digikey.com·and search for your part number.· Searching the Digikey catalog just reminds me I need to see an optometrist.
Chris I.
·1+1=10
