Production
                    Just wondering, have you guys ever thought of having a version of the BOE or NX1000 that has a ziff socket?
That way those of us planning to build product based on Stamps can do a quick change of processors without worrying about bending pins when programming a batch of them.
"Never create anything you can't control"
"The amount of intelligence on the planet is fixed... the population is growing"
Sid Weaver
Do you have a Stamp Tester yet?
http://hometown.aol.com/newzed/index.html
Jon Williams
Would this one work? If so, I'll order a few more and try them on a BOE or two.
Cheers,
Doc
·· That sure will work.· In fact I think I have a few of that exact ZIF Socket floating around my parts bins.
Chris Savage
Parallax Tech Support
csavage@parallax.com
Greetings from Germany,
G
In order to use it, I had to solder it to a board that I used to support 24 longer pins.
You need a board that will allow you to solder from both sides. A single sided proto-type board will not work.
G. Herzog in Taiwan
Sid Weaver
