Production — Parallax Forums
Production
DannyDanny Posts: 56
edited 2005-09-25 16:48 in General Discussion
Just wondering, have you guys ever thought of having a version of the BOE or NX1000 that has a ziff socket?
That way those of us planning to build product based on Stamps can do a quick change of processors without worrying about bending pins when programming a batch of them.
"Never create anything you can't control"
"The amount of intelligence on the planet is fixed... the population is growing"
  • NewzedNewzed Posts: 2,503
    edited 2005-09-23 18:11
    You can buy a ZIF socket from Digikey that plugs into the Stamp Socket.
    Sid Weaver
    Do you have a Stamp Tester yet?
    edited 2005-09-23 18:37
    ZIF sockets are not cheap, and we are constantly hounded to lower our prices. Sid has a good solution for those of us who change chips frequently.
    Jon Williams
  • doggiedocdoggiedoc Posts: 2,248
    edited 2005-09-24 01:50
    That's a great idea! I have bent a pin or two and I am very careful. I ordered a couple for my ATMEL programmer I built but it never occured to me to use them on my Parallax boards.
    Would this one work? If so, I'll order a few more and try them on a BOE or two.
    Cheers,
    Doc
    edited 2005-09-24 03:12
    Doc,
    ·· That sure will work.· In fact I think I have a few of that exact ZIF Socket floating around my parts bins.
    csavage@parallax.com
  • Guenther DaubachGuenther Daubach Posts: 1,321
    edited 2005-09-24 09:36
    A Textool 228-1371-00 would do the job.
    Greetings from Germany,
    G
    edited 2005-09-25 16:43
    The pins on the Zif that I bought were too short.
    In order to use it, I had to solder it to a board that I used to support 24 longer pins.
    You need a board that will allow you to solder from both sides. A single sided proto-type board will not work.
    G. Herzog in Taiwan
    If the pins are too short, you can plug it into a 24-pin .600 machine collet DIP socket, then plug it into the Stamp socket.· I've done that many times.
    Sid Weaver
