Anyone Have INfo or tutorial on using the stamp with a modem, Especially the Ce — Parallax Forums
hybridhybrid Posts: 16
edited 2005-09-15 17:44 in BASIC Stamp
Hi everyone. Does anyone know or have any tutorials on using the stamp with a modem. The parallax site offers a modem kit, but is now discontinued. I could use a really good informational document. Thank you
    edited 2005-09-10 21:02
    Before working for Parallax I used a Cermetek modem in an application and found them not particularly easy to deal with.· But, if you want to give it a go, this article (about 5 years old) may help: http://www.parallax.com/dl/docs/cols/nv/vol2/col/nv60.pdf
    Jon Williams
    edited 2005-09-10 22:11
    Try this, maybe will have information you can use...
    www.emesys.com/BS2modem.htm
    Tracy Allen
    www.emesystems.com
  • Ken GraceyKen Gracey Posts: 7,416
    edited 2005-09-10 23:45
    Hybrid,
    Attached is our documentation for the discontinued StampModem. You can still build this circuit on a breadboard (or the Professional Development Board) and run our code as an example.
    edited 2005-09-10 23:48
    Hybrid,
    Yet another download which was published in Nuts and Volts:
    Modem Lets Stamp Acccess World-Wide Network
  • steve_bsteve_b Posts: 1,563
    edited 2005-09-11 14:17
    I've been able to use a regular external USR14.4 modem with my stamp.·
    To be honest, I only bench tested it...but was able to dial out without a problem -- I was looking for a remote data acq system that would dial out and dump it's data to a central database....so it was a bench test in that respect.
    All I did was hack apart a modem cable and wire to the stamp.
    I honestly don't remember where I left off....but I think I had borrowed from the Cermeteck code and modified it here and there....didn't clean it ALL up!
    I actually don't remember which one I finished on....but I'm thinking its the long file named one (as I've included more remarks in the code).
    Steve
    "Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
  • hybridhybrid Posts: 16
    edited 2005-09-13 00:01
    Thank you everyone. All of these links are very helpful.
  • Ryan ClarkeRyan Clarke Posts: 738
    edited 2005-09-14 14:55
    The our Cermetek CH1786A docs were recently updated here:
    http://www.parallax.com/detail.asp?product_id=603-00011
    Also note the new lower price.
    Ryan
    Ryan Clarke
    Parallax Tech Support
    RClarke@Parallax.com
    Post Edited (Ryan Clarke (Parallax)) : 9/16/2005 6:26:34 PM GMT
    edited 2005-09-15 15:34
    Hi Ryan,
    Are your sure about that 14.4 and caller ID business? I think those capabilities apply to the CH1788, but not the CH1786A. It looks to me from the data sheet that the CH1786A is still 2400 baud max, and the differences with the older model are minor enhancements in the handshake options and changes in the default settings.
    I bought a pile of surplus Macintosh Teleport modems at less than $1 each, that were designed to operate with 5 volt power and 5 volt data levels. It was a pretty easy matter to hook those up to the Stamp. I still see them around on surplus.
    Tracy Allen
    www.emesystems.com
    We support the chip as it's rated per their documentation.
    Here is a picture of it running on our PDB.
    Ryan
    Ryan Clarke
    Post Edited (Ryan Clarke (Parallax)) : 9/16/2005 6:27:31 PM GMT
    600 x 358 - 64K
