Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
Command — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
BASIC Stamp
Command
leshea2
83
2005-09-06 20:25
edited 2005-09-06 20:46
in
BASIC Stamp
What’s the main difference between the DATA command and the Write command, which one would work the best for loading information to the stamp ?
Thanks !
Jon Williams
6,491
2005-09-06 20:46
DATA stores the information in EEPROM at download time; WRITE puts it there while the program is running.
By the way, you'll probably get more responses if you add a bit of detail to your subject line.
Jon Williams
Sign In
Register
to comment.
Jon Williams
