Command — Parallax Forums
Command
leshea2leshea2 Posts: 83
edited 2005-09-06 20:46 in BASIC Stamp
What’s the main difference between the DATA command and the Write command, which one would work the best for loading information to the stamp ?
Thanks !
    DATA stores the information in EEPROM at download time; WRITE puts it there while the program is running.
    By the way, you'll probably get more responses if you add a bit of detail to your subject line.
    Jon Williams
