Maximum Data Cable Length — Parallax Forums
hcwonghcwong Posts: 38
edited 2005-08-28 22:10 in BASIC Stamp
Dear all,
Kindly point out to me what is the maximum allowable data cable length for each communication type below:
1) RS232
2) USB 2.0
3) RS485
Thanks.
  • dandreaedandreae Posts: 1,375
    edited 2005-08-26 22:45
    I bet if you type this information·into www.google.com it will come up with the information that you are looking for.
    I came up with:
    50ft. for RS-232
    4000ft. for RS-485
    16.4ft for USB 2.0
    Dave
    Dave Andreae
    Tech Support
    dandreae@parallax.com
    Http://www.parallax.com
    Post Edited (Dave Andreae (Parallax)) : 8/26/2005 10:46:59 PM GMT
  • steve_bsteve_b Posts: 1,563
    edited 2005-08-26 23:00
    I concur with the "documented" range for rs232....however, I've got a 200ft cable run at the moment on a shielded cable running at 2400 baud and don't seem to have any problems...
    So dropping your baud rate will give you enough head room to stretch the distance out!
    Steve
    "Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
    edited 2005-08-26 23:10
    Speed is going to be directly proportional to cable length. Slower bauds will do just fine, but Higher speeds will get swamped with the "capacitance" induced over long cable runs.
    Beau Schwabe
    IC Layout Engineer
  • knightofoldcodeknightofoldcode Posts: 233
    edited 2005-08-27 00:04
    Dave Andreae (Parallax) said...
    I bet if you type this information into www.google.com it will come up with the information that you are looking for.
    I came up with:
    50ft. for RS-232
    4000ft. for RS-485
    16.4ft for USB 2.0
    Dave
    Note, These values assume no active repeating. With Active Repeating, these distances can be much larger.
    Knight.
  • hcwonghcwong Posts: 38
    Thanks folks for pointing it out.
