Radio Frequency Communication
I would like to construct a semi-autonomous basic stamp robot (similar to the Mars Explorer robots with a shorter communication range...
·).· This robot will need to be able to receive commands and transmit data.· Ideally, I would like to be able to send and receive commands from a PC but I could get by with a second basic stamp unit connected to the computer that relays commands to the robot and recieves data from the robot.· Commands would be simple transmissions but data could be as complicated as photographic data (no video).
Does anyone have suggestions for hardware to accomplish the communications?· What are the benefits and limitations of that hardware?
Roger Ray
·).· This robot will need to be able to receive commands and transmit data.· Ideally, I would like to be able to send and receive commands from a PC but I could get by with a second basic stamp unit connected to the computer that relays commands to the robot and recieves data from the robot.· Commands would be simple transmissions but data could be as complicated as photographic data (no video).Does anyone have suggestions for hardware to accomplish the communications?· What are the benefits and limitations of that hardware?
Roger Ray
·· Most people defer the two signals to different devices.· IOW, the commands are sent to the robot (And in some cases received back) through a wireless serial link, of which we have several options, including BlueTooth.· As for the Photo/Video data, the more common method is to use a camera with it's own 2.4Ghz transmitter, and a 2.4Ghz received at the base station.· X-10 is a good source of such cameras.
Chris Savage
Parallax Tech Support
csavage@parallax.com
While the Bluetooth hardware is full of features, you could do this with the following parts:
http://www.parallax.com/html_pages/resources/catapps/cat_radiobot.asp
This would provide a Hyperterminal or Stamp DEBUG interface to control the robot.
The wireless video would be on a separate frequency, probably 2.4 Ghz as Chris suggested.
Regards, Provas, GREECE
-Rule your Destiny-
--Be Good. Be Bad. Be Provas--
·1+1=10
Very soon we will solve the "cost issue" of our RF modules in a BIG way. I assure you that you won't complain about the cost of our RF devices in 30 days from now.
But for now, you're exactly right. They're way too expensive.
