PWMPal, Reversible R/C ESC's, and the Basic Stamp 2 — Parallax Forums
AudiorigamiAudiorigami Posts: 3
edited 2005-08-23 17:08 in Robotics
I've got a BS2 and a Novak Super Rooster reversible ESC from an R/C car. The ESC acts as an h-bridge, accepting PWM and controlling a DC motor.
A PULSOUT loop on the BS2 will allow me to create PWM of the type that the ESC wants, but at much too low a frequency. Because the PAUSE command has a 1 ms minimum, my frequency is limited to 60Hz when I'd rather be operating in the 1kHz range. As a result, I get spotty response from the ESC.
My question is this: will the PWMPal help? Can it allow me to control the duty cycle at 1khz or more? Can I control three such ESC's and still do other processing if I get the PWMPal?
Thanks in advance!
    edited 2005-08-01 20:28
    The PWMPAL should work fine for you -- just consider the frequency versus duty-cycle resolution.· The high- and low-time resolution is 25 microsecods.· A 1 kHz period is 1 millisecond, so your output control will be limited to 2.5% (100% / (0.001 / 0.000025)).· If you can live with 2.5% resolution on your PWM signal, then you're good to go.
    Jon Williams
  • AudiorigamiAudiorigami Posts: 3
    Thanks a lot, it worked. I have a PWMPAL working as a controller for two Novak Super Roosters, if anyone has any questions about them.
    Next question: My ESCs, the Super Roosters, can only handle 12v. I'd like to use the Motor Mind C instead--will I still need the PWMPAL to obtain a good range of frequencies/duty cycles, or will the Motor Mind C and BS2 work fine together without the PWMPAL?
