PWMPal, Reversible R/C ESC's, and the Basic Stamp 2
I've got a BS2 and a Novak Super Rooster reversible ESC from an R/C car. The ESC acts as an h-bridge, accepting PWM and controlling a DC motor.
A PULSOUT loop on the BS2 will allow me to create PWM of the type that the ESC wants, but at much too low a frequency. Because the PAUSE command has a 1 ms minimum, my frequency is limited to 60Hz when I'd rather be operating in the 1kHz range. As a result, I get spotty response from the ESC.
My question is this: will the PWMPal help? Can it allow me to control the duty cycle at 1khz or more? Can I control three such ESC's and still do other processing if I get the PWMPal?
Thanks in advance!
Thanks in advance!
Jon Williams
Next question: My ESCs, the Super Roosters, can only handle 12v. I'd like to use the Motor Mind C instead--will I still need the PWMPAL to obtain a good range of frequencies/duty cycles, or will the Motor Mind C and BS2 work fine together without the PWMPAL?
