Analog output from BasicStamp? (Replacing an analog pot with control from BS2) — Parallax Forums
TonyATonyA Posts: 226
edited 2005-08-21 01:08 in BASIC Stamp
Hi,
I am trying to achieve an analog output from the BS2. I 've read that you can simulate analog output using PWM.
Is there a way you can get a resistance output from the BS2?
What I'd like to do is replace an analog potentiometer on a certain device with control by way of the BS2.
Would a digital pot chip come into this? Or a digital to analog chip?
Thanks for any help, I appreciate it.
Tony
    edited 2005-08-19 19:19
    There are several application notes on how to do this... My favorite chips for doing this·are the DS1267 (Dual Pot) and the AD8803 (Octal Pot).
    Here is an example that I did a few years ago...
    http://webpages.charter.net/schwabelove/BasicStamp/
    ...See:
    "AD8803 Octal Digital POT interface"
    "DS1267 Dual Digital Resistor Interface"
    "Radio Control Electronic Speed Controller using a Stamp1" for code and schematics.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 8/19/2005 7:22:34 PM GMT
  • TonyATonyA Posts: 226
    edited 2005-08-19 19:25
    Hi Beau,
    Thanks for your help. Interesting projects there.
    If I wanted just one pot control would the ad5220 work for controlling a simple analog oscillator?
    (I noticed something on your site that gave me an idea. How could I go about getting a control voltage (CV out) output from the BS2?)
    Thanks again,
    Tony
    Post Edited (TonyA) : 8/19/2005 7:30:40 PM GMT
    edited 2005-08-19 19:28
    I think it might help if we knew more of what you were trying to do in order for us to optimize the solution.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-08-19 19:30
    Beau,
    I want to control a simple oscillator with the BS2. replace the oscillator's analog pot (used to control the oscillator) with control via the BS2.
    Tony
    edited 2005-08-19 19:35
    What does the schematic of your oscillator look like? If the pot has a common node to power or gnd, then you may not need a digital pot at all.
    You might be able to get away with using the PWM command with an OpAmp set as a voltage follower.
    Beau Schwabe
    IC Layout Engineer
    edited 2005-08-19 19:56
    Hi,
    I am looking into the possibilities of using the BS2 to control very simple oscillators (sound effects). The types of oscillators
    you could make from a 555 timer chip and the chip in the attached schematic.
    Also, how I might make a simple control voltage output. The type of CV used for analog musical synthesizers/oscillators. (I don't know too much about this stuff, so sorry if I am using the wrong terminology). The CV output would be used so that you could plug into an analog synth and control it.
    These are my 2 objectives. I am interested in applications that involve sound manipulation and control. I have already worked somewhat with midi.
    Thanks again for your help, I really appreciate anything you can impart to me.
    Tony
    The attached schem is from a kit available from electronicgoldmine.com *I want to be able to replace the cds cell with controll fron the BS2.
    Post Edited (TonyA) : 8/19/2005 7:58:23 PM GMT
    1275 x 1755 - 262K
    edited 2005-08-20 03:40
    Tony said...
    There are a couple of ways... One is to use a DAC (digital to analog converter) IC.
    Another is to use the PWM command in combination with an OpAmp configured as
    a voltage follower. (See attached schematic)
    Beau Schwabe
    IC Layout Engineer
    885 x 583 - 11K
    Thank you for your help. I will give this a try.
    Tony
