OptoIsolation and RS232 issue — Parallax Forums
KoyJaKoyJa Posts: 17
edited 2005-08-19 17:31 in BASIC Stamp
Im having an issue with a PCB I mad using the BSP240. To eliminate the 60Hz noise
coming accross the RS232 port I have Optically Isolated the Stamp serial port
from the DB9 RS232, I am also using a DC/DC converter to give me seperate rails
5V1 GND1 (STAMP) 5V2 GND2 (RS232). I can send data to the Debug screen with no
Issues, this works great. My problem is I am not able to Identify or program the Stamp
(I have to connect directly to the Stamp with 4 header pins to program it)
I have attached a schematic for reference :
The MAX232 Im using gives me the proper voltages the Pumps are working (+10 -10)
and like I mentioned before I can send data to the Debug Window. I also tried putting
a .1uf cap Inline with the DTR Pin like it shows in the Manual, but it still doesnt work.
All static volatges with the conector on seem to be·fine .... however since Im using
an R2232 driver the output is TTL levels .... so I have .125mv on all pins instead of·~ -8.0v
if I were to·connecting directly to the Serial port. If anyone has tried this before I would
appreciate any advice.
mike
KoyJa
232.bmp 385.1K
    edited 2005-08-15 04:13
    Mike,
    ·· The BASIC Stamp pins can handle the RS232 voltages directly, but now you're feeding them through both a MAX232 and an opto-isolator.· That's got to be messing with the signals in a bad way.· If you were having a problem with a 60hz noise, you should've handled that another way than to convert the signals going in/out the Stamp Module twice.· I'd really have to do some thinking just to decide if the right signals are coming/going from the Stamp Module at this point.
    Chris Savage
    Parallax Tech Support
    csavage@parallax.com
  • KoyJaKoyJa Posts: 17
    edited 2005-08-15 04:38
    Hi Chris,
    Thanks for your reply. I am not going through the STAMP twice with my signals. I am however like you pointed out
    inverting the signals twice to get the same signal if I didnt use the max232 and opto staright TTL level·:
    ---· 10V TX DB9
    > 10V 232In
    > 0V 232out to Opto in ---- 5V Optout switch open ----> 5V to Pin2 Stamp SIN
    As my schematic shows the same setup is used for the DTR to ATN Path.
    The schematic shows using a .1uf cap on the DTR line, however I believe I cant do this because I have Isolation
    implemented. Im thinking I have a rest issue .... can you supply me a techinal detail why these .1uf caps are used?
    mike
    KoyJa
  • Philip GamblinPhilip Gamblin Posts: 202
    It is possible between the MAX232 and the opto couplers you have inverted the polarity of the rs232 signals. Elaborating on what Chris said, you should be able to connect your PC to the stamp using the method in this document http://www.parallax.com/dl/docs/prod/schem/bs2p40SchemRevB.pdf. The BS2P40 has the RS232 level translation hardware on board the module. I suspect if you measure from ground on the stamp to ground on the device you are interfacing to , you will find probably a small AC voltage. Connecting the stamp gnd to the frame of the interfacing device may eliminate the problem.
    edited 2005-08-15 05:21
    Mike,
    ·· The reason for the .1uF caps on the DTR/ATN ine is that some computers hold the DTR line high when the port is idle.· Some software does this as well.· When this happens the Stamp Module is held in a RESET state, since a high on the DTR/ATN lines holds the RESET line LOW.· The cap prevents the line from being held (Blocks DC).·
    ·· Two possibilities exist though to defeat this.· One is that the line is toggling.· Rarely this has been seen on some computers and the only thing to do then is unplug the cable after programming.· The other is on your case, if you have noise, it could be affecting the circuit, rendering it useless.
    ·· Just because you have isolation does not mean you cannot use the capacitor.· It can still be connected between the ATN line and whatever is driving it.· However, I believe in your signal conversions (Of which you are doing twice, that I was referring to) you could be conflicting either with the timing, and/or the proper signal levels to properly program the Stamp Module.
    Chris Savage
    edited 2005-08-15 06:54
    Ill try the .1 uf from the DB9 side of the opto and see if that helps. Does Parallax have
    a timing diagram for the "Identify Sequence" ..... hmmmm good excuse to get a 4 channel
    scope.
    Thanks again
    mike
    KoyJa
  • steve_bsteve_b Posts: 1,563
    edited 2005-08-15 13:14
    I'm thinking that when you are debugging, you are using TRUE Serial (as opposed to Inverted BAudmode values).
    This is what the MAX232 expects and will take the true TTL data and "RS-232" it (which inverts it and pumps it to 10/12volts).
    When you are trying to program the stamp, you are sending proper RS232 signals from your pc....the MAX232 takes this and creates true TTL....which the Stamp DB9 connector can't use. It has to have RS232in the fashion of a "1" being 0volts and a "0" being 10volts.
    (when you have a logic 1 on your RS232 line it shows as a space <or 0volts>; this logic 1 should also be showing at the stamp pin as well as a +5v line....do you have a scope to see these things in proper time?....not sure if you could just hold your rs232 line high and tracing back the signal <you are doing this with the ATN line...maybe you can...>
    Parallax can answer if the stamp programming port will work on 5volts (I've never tried...) but the TX line from the PC is the line that does 'power' the rs232 transistor pumps for the stamps programming port communications....so you do have to have a proper voltage there to power the stamps TX line.
    I would've put the opto's before the max232....if it doubles as surge protection then why not protect as many ICs as possible and put the MAX232 after the opto's....
    and in so doing, it might help clear up some problems as far as inverted this or inverted that....
    Steve
    "Inside each and every one of us is our one, true authentic swing. Something we was born with. Something that's ours and ours alone. Something that can't be learned... something that's got to be remembered."
    edited 2005-08-15 14:39
    KoyJa said...(trimmed)
    Does Parallax have a timing diagram for the "Identify Sequence" ..... hmmmm good excuse to get a 4 channel
    scope.
    The timing for the program sequence can be found at the following link:
    http://www.parallax.com/html_pages/downloads/tokenizer/tokenizer.asp
    The Tokenizer Library documentation explains what happens during identify and program sequences.
    Chris Savage
    edited 2005-08-15 15:52
    Mike,
    ·· Some things pointed out by one of our engineers...
    1) Bear in mind that Sin/Sout always functions in inverted polarity mode, regardless of the SERIN/SEROUT command you use.· DEBUG always outputs inverted data on that port as well.
    2) Your schematic does not show R6 (Of the DTR circuit) connected to Vdd.· Do you actually have that included?
    3) On the BS2p40-side of the Opto, you should probably have wired it differently.· It's possibly that the 4.7K pull-up just isn't strong enough to pull-up to cause a reset (Remember, the Stamp expects that line to be disconnected most of the time).· It would be better to use a very small resistor, or, better yet, wire so that it pulls down weakly to ground, but drives to 5 volts (Instead of pulling wekly to 5V and driving to ground).
    4) You could try monitoring the signals on a scope.· Make sure the DB9 DTR line and the Stamp ATN pin switch at nearly the same time without much slew (If everything is working properly).
    Chris Savage
    edited 2005-08-16 05:57
    Chris,
    Thanks for the Basic Stamp Programming Protocol. I have been able to determine that
    timing is not an issue, however voltage levels might be. The spec say it accepts
    true 232 signals and I am using TTL. However the Stamp is going into the reset phase,
    it inversly follows the DTR pin so that good to know. This weekend I will borrow a 4 chanel
    scope to comapre a good condition with what I am having now.
    Im using a 2 Chanel Fluke scope meter now, so Ill hook up the other scope
    to my 232 signals before the isolation.
    mike
    edited 2005-08-16 14:53
    Mike,
    ·· Good luck!
    Chris Savage
    edited 2005-08-17 06:34
    It seems to me that the Max232 is really operating on both sides of the 'isolation barrier'.
    Does that really work?
    Gunther had a much simpler arrangement which uses the optoisolators as the drivers and recievers. Less chip count, just one inversions [noparse][[/noparse]which is right], and a bit cheaper, faster to build.
    G. Herzog in Taiwan
    edited 2005-08-17 12:08
    I had a terrible time trying to find my circuit for precisely what gunther was talking about!
    Here it is! [noparse]:p[/noparse]
    Steve
    1024 x 820 - 77K
    edited 2005-08-18 07:51
    Thanks for the schematic Steve .... I used an NME0505 Dc/DC converter because I was
    receiving 60hz coming into my circuit. So far I have only been able to send data with
    the way I have the circuit wired. Luckily I put headers near the Stamps Serial ports
    so I have been able to continue with the project until I get a 4 channel scope to debug
    the issue further.
    This STAMP stuff is gettting way out of hand !!!! But at least I get to tell the ex-wifey :
    " Sorry Baby Im STAMPING this month I dont have any extra money"
    Heres a PIC of the continuing 3 year Project and another of me dropping by the Parallax HQ
    on a Sunday a couple of weeks ago looking to see if they were having a Garage sell [noparse];)[/noparse]
    Mikey
    KoyJa
    2560 x 1920 - 380K
    2560 x 1920 - 235K
    edited 2005-08-18 14:18
    Nice pics!· So what's the circuit do?· (Or what's it supposed to do?)· =)
    Chris Savage
    edited 2005-08-19 03:18
    Glad to see someone make it to the promised land!
    edited 2005-08-19 10:11
    Hi Chris,
    This originall started out as a basic wrist strap tester * 3 years ago, no Micro and 2 comparators.
    Wrist strap testers check the Safety 1M resistor found in most wrist straps
    Now its evolved
    to testing :
    Implemented
    1. Wrist Straps
    2. Foot Straps (Both Left and Right simotaniuosly)
    3. VB Based logging softwrae
    4. Auto ID (Using Dallas/Maxim I-button on wrist and foot strap)
    5. Temp/Humidity
    6. Testing Stand with metal footplates
    7. Internal Calibration resistor
    8. LCD Interface (haha Done Today!)
    9. No hands testing
    All Footstrap Testers require you to Touch a Metalic Tab to complete the voltage divider, but by using
    the Stamp controlling relays I can measure both FootStraps in series by just standing on the test STand
    COming soon ! :
    Voice capability with the speaker Jet "Chris Savage your Wrist strap is within acceptable Limits"
    Keypad Interface
    Calibration Box
    I have Moduler connectors on the Left, Right and Top of the Board. Each side has Power and ground
    then the rest are connected to the Stamps I/O pins. I found a cool set of Enclosures from :
    http://polycase.com/ag-prod.asp
    These come in different sizes but the same shape.
    None of this would have been possible for me with out the STAMP! Im a Network Admin by day and a
    wanna be designer by night. My partner wants to trim costs by using a diff Micro .... I told him to
    suck wind!!! If we use a diff micro whos going to get up at 2 AM and debug the darn thing, whos going
    to design more modules in this?? I have great respect for the Assembly Junkies out there ... but on my best
    day 1 + 1 = 1.85 The way I look at it ... the stamp gives me complete control for future Modules and support.
    It may take me a coup[noparse][[/noparse]le weeks longer than someone who actually knows what there doing .... But these STAPMS
    are forgiving ... and there patient. hmmmm just dont cross 100V on Vdd .... lessons learned, I was just lucky
    I had parts on BackOrder for longer than usual and you guys sent me another on !!!!! Thats when I became a
    Happy STamper
    All joking aside you guys have one heck of a product line and the phone and forum support is awesome.
    Heres a couple of itmes for the Suggestion Box :
    1. Webinar
    Theres a Analog guru named Bob Pease from Nation Semi .... he has this online show called :
    "The Bob Pease Show". Wow those shows are great, It would be cool if you guys could think about doing something like
    this for New Products, showing online demos code snippets. And maybe even a User Projects section. I belive Tektronics
    supports them they always have a rep from there.
    2. ExpressPcb
    Being a Jack of all trades and Master of none ..... This layout software is great for the guy who wants to layout his own boards
    and get them produced. It would be nice to have OEM footprints for all your parts in there library. Maybe even strike a deal for discounts
    for Stamp Users.
    Here the latest PIC with the attached 4x20 ..... errrr you guys discontinued the one I used before so I need to rewrite
    my code from the last Breadboarded project.
    Thanks Agin guys !
    mikey
    Koy Ja !
    2560 x 1920 - 327K
    Mike,
    ·· Very nice...Looks like commercial quality!· It's always nice to see some of the ways people put their Stamp experience to good use.· We at Parallax use our own products for internal use as well.· We will be posting some pictures soon of our latest project.· =)
    Chris Savage
