Using SPDT with center off to toggle three modes — Parallax Forums
TorquewrenchTorquewrench Posts: 28
edited 2005-08-18 01:48 in BASIC Stamp
Hi,
I'm interested in using an SPDT with center off (three-position toggle switch) to choose between three modes. The one example I have for this involved using an analog input on a Microchip microcontroller (I've attached the schematic below) and the pin would sense 5V, 2.5V, or 0V. How can I implement the same functionality (toggling between three modes) on a BS2, preferably without any additional ICs and as compactly as possible.
Thank you,
Phil
  • dandreaedandreae Posts: 1,375
    edited 2005-08-14 14:43
    Try this link:
    http://64.233.161.104/search?q=cache:mfH36R6QIF4J:www.parallax.com/dl/docs/cols/nv/vol1/col/nv23.pdf+SPDT+switch+and+BASIC+Stamp&hl=en
    I know that this link rather long, however, I basically went and did a search on www.google.com for "SPDT switch and BASIC Stamp" and found this information.
    Dave
    Dave Andreae
    Tech Support
    dandreae@parallax.com
    Http://www.parallax.com
  • TorquewrenchTorquewrench Posts: 28
    edited 2005-08-14 15:02
    I took a look at the link, it appears to be an article about motor controller circuits. Did you mean to point me to something else perhaps?
    What I'm looking for is a combination of circuitry and code that will tell the stamp to be in one of three modes based on the position of a three position toggle switch.
    Thank again,
    Phil
    edited 2005-08-14 15:35
    Phil -
    As I remember Beau Schwabe has a method of obtaining a tri-state result from one pin port, which is essentially what you're looking to do with a SPDT C/O toggle switch. I'm sure as soon as he sees this thread, he will chime in. I THINK it was done with RCTIME and a resistor divider network, but don't hold me to that.
    Perhaps Parallax might donate a small corner of their excellent web site (say "Parallax Tech Reps - Tech Notes") for the very helpful general applications notes, and schematics that Beau used to keep on his own web site when he had it. That was a WEALTH of Stamp and analog information. Beau had/has circuits for lots of things which seemed like they couldn't be done, or couldn't be done easily.
    I'd be willing to bet there are other Parallax Tech Reps who might well have their own hidden trove of innovative Stamp tricks and circuity tricks which fall out of the ordinary scope of documented Stamp Applications. Some of us would just love to raid John B's hard drive for "super-circuits" some time smile.gif
    Bruce Bates
    edited 2005-08-14 16:40
    Let me dig around.... I have family in town this morning, so it might be a little while before I can get to it.
    Beau Schwabe
    IC Layout Engineer
  • Philip GamblinPhilip Gamblin Posts: 202
    edited 2005-08-14 18:23
    The RCTIME angle seems a good approach. Example three switch positions A, B, Center. Center positon has a 5K to input PinX the A position is also a 5K resistor but in the A posito it is in series with the aforementined 5K so it reads 10K total resistance. B position has a 10 K resistor and thus in the B, 15 K resistance is presented to the pin. Positions A,B and Center now read 5, 10, and 15 K ohms respectively. Utilizing thie scheme with RCTIME will give you three distinct values as input to your code. The the resistors can be almost any values as along as they don't cause rctime to count too long with the cap you're using. Additionally, you want the RCTIME values far enough a part that your program can tell them apart.
    edited 2005-08-14 21:27
    Bruce,
    After digging...· my solution for "obtaining a tri-state result from one pin port" was going from the stamp.· I think what Phil is looking for needs to go to the stamp.
    There are certainly other ways to do this, but I think that the RCTIME approach would be the best solution for least amount of·I/O pins.
    Bruce Bates said...
    This subject has not really·been brought up.· The "web-page" died because of problems I was having with my service provider at the time.· After many attempts to
    revive the web site, it was just never the same due to the number of broken links other people had (and still have) that point to my old sight.
    Bruce and all that remember,
    Here is the sight as you might remember it...
    http://webpages.charter.net/schwabelove/BasicStamp/
    Phil,
    Check out the 3x5 keypad·as an alternate·solution for what you want to do.
    Beau Schwabe
    IC Layout Engineer
    Post Edited (Beau Schwabe (Parallax)) : 8/14/2005 9:32:51 PM GMT
    edited 2005-08-14 22:05
    Any chance someone could throw up a quick sample schematic?
    Phil
    edited 2005-08-15 00:43
    I hope this helps. First read up on the RCTIME command. Don't get caught up in all the arithmetic. RCTIME is a very usefull command. Here's a brief summary of what is in the help file. The command··· · RCTIME Pin, State, Variable···· RCTIME will charge C1 through R3. R3 is a current limiting resistor to protect the stamp pin. First the cap is charged by setting PIN to a high state , Pause for a few milliseconds, then RCTIME turns·Pin into·an input. A timer is started. As long as·Pin·is in the·STATE·· High (or Low) condition, the timer is running. The timer stops when the cap discharges below the Logic high threshold.·The·RCTIME command returns a value which indicates how long it takes for the capacitor to discharge.
    With that bit of background, ( The Help file does a much better job of explaining RCTIME ) The switch is not correctly drawn, just recognize that in the center (off) position, the capacitor discharges only through R1 with the switch in the A or B position will place R2 or R3 in parallel with R1. Which will decrease the resistance through which C1 discharges and reduce the time stored in Variable.
    Suggestion. Start with just R1 and C1 experiment with different values to understand how the command works. Then install the switch and the additional resistors. None of the resistor values are critical, you just need to be able to reliably differentiate between the two states. Good Luck and Happy Stamping.
    ·I can't open my attachment, I hope you can.
    Post Edited (Philip Gamblin) : 8/15/2005 4:43:55 AM GMT
    edited 2005-08-15 10:38
    The attachment is fine, just needed to add the .bmp extension. Great explanation, I'll give it a try tonight.
    Phil
    edited 2005-08-17 20:09
    Philip Gamblin,
    Do you mean to not connect the center/off pin to anything, or should it be connected to ground?
    edited 2005-08-18 01:32
    I'm considering using a three position rotary switch instead of the SPDT with center off. The rotary switch is offered as an SP3T, BCD, or HEX. Would BCD or HEX allow me to connect the switch to the stamp without the RC circuitry and make for a simpler board?
    These are the switches I'm considering:
    RTE Series Miniature Rotary Switches
    3 position selector, 4 x 7.5 mm shaft, silver plating, Digikey p/n 401-1028-ND, $2.05, RTE0301N01
    3 position selector, button actuator, silver plating, Digikey p/n 401-1029-ND, $2.05, R0302N01
    http://dkc3.digikey.com/PDF/T052/1200.pdf
    Phil
    I think I answered my own question with regards to the hex and bcd switches, they have more positions than I need. Any comments are welcome, as always.
    Phil
